How to backup the button mapping config (.scg) file?
velvetk213
Post by velvetk213 »
Hi all!
I got spacepilot , using it with pro-e wf 3.0.
Recently i have to format my disks , i'll tried to copy the .scg , with the hope to not sped time to create new buttons mappping config. But.... it did'nt reconize the buttons mapping.
Someone can help me??
Any suggest.
Tanks anyway
Bye
Bryan
Backing up the button mapping config (.scg) file?
Post by Bryan »
Dear velvetk213,
Exactly where did you copy them from?
Where did you copy them to?
Did you change operating systems?
Did you change versions of application software?
Are you checking your button mappings in the same mode they were created in?
Did you change your version of 3DxSoftware?
When you say "it didn't recognize the buttons mappings.", what were experiencing? Did you get an error message?
Sincerely,
Bryan
velvetk213
Re: Backing up the button mapping config (.scg) file?
Bryan wrote:Dear velvetk213,
Sincerely,
Bryan
Hi Bryan!
I copied the .scg file from C:\Users\.......\AppData\Roaming\3Dconnexion\3DxWare\profiles
and i put it in the same dir , after the new installation of same O.S. and all the programs including the 3d connexion software.
(to access to the dir position you must change the folder option to show hidden folders)
And when i started pro-e , i saw that all the buttons assigns was loose. It was returned to the default state. All my macros button assign was blank.
I got to spend time to re-assign my buttons choice. Whitout any error messages.
Is there a way to backup this file? if i connect my spacepilot to another pc (same O.s) can i copy this file ,to start working immediately?
I only change to the new update of 3dxware after re-making all the button assigns.
Tanks
Regards
Bye
Bryan
Post by Bryan »
Dear velvetk213,
You can back up them up like any other file. They're simply text files. If you make copies of them and place in another's user's profile or in your profile on a different machine, they should be available to you.
Sincerely,
Bryan G.
If you have 3DxProE installed, the settings are not saved in .scg files.
Bryan
Post by Bryan »
Dear velvetk213,
In general,
Each user's configuration's .scg files are saved
under their name,
C:\Documents and Settings\<username>\Application
Data\3Dconnexion\3DxWare\profiles
While the drivers and plugs-ins originate from
C:/Program Files/3Dconnexion/...
So when new drivers are installed, each user's
configurations files should remained nicely nestled under
each individual's user's profile.
If a user were to move to a different machine, he
could copy these .scg files over.
But normally updating drives should not make any
changes to settings and button mappings that a user may
have individualized.
However some applications do also make use of the
registery.
Our Plug-ins also use the registry:
HKEY_CURRENT_USER\Software\3Dconnexion
For example, if SolidWorks gets started, our Plug-in looks
for “HKEY_CURRENT_USER\Software\3Dconnexion\3Dconnexion
Add-In for SolidWorks” – if this key is not present it
will be created while starting SolidWorks. If you do not
have SolidWorks installed there is no such key.
In order to transfer settings from one computer to the
other the corresponding registry-entries have to be
exported and imported.
(In SolidWorks under the 3Dcontrol Menu there are Export
and Import Items for this.)
For ProE we use the following Key:
HKEY_CURRENT_USER\Software\3Dconnexion\3DxProE
In ProE we store all button mappings under this key that
are different to the default mapping. This key is also
only present if ProE was started. To transfer the
mappings you can export this key and import it to the new
machine
Sincerely,
Bryan
