Working Driver for 3DSMax9 64bit Available?
tmacbriar
Post by tmacbriar »
Can a functioning older driver be made available for 3DSMax9 64bit, as the current driver available for download is not functional? I have just purchased SpaceExplorer, so I have no previous drivers.
tmacbriar
Copper Parrot Studios
www.copper-parrot.com
znissan
User
User
Post by znissan »
Hello:
Could you please post this question in the Windows forum so that the right support people and also others will be able to view it?
Ziva Nissan
3Dconnexion, Inc.
Moved to Windows forum.
tmacbriar
Any Hope
Post by tmacbriar »
I was hoping that someone would be able to post a previous driver to use until the new driver (2 to 3 weeks) becomes available. I sure would like to be able to use this piece of equipment after purchasing it in good faith to use with 3DS Max 9.
tmacbriar
Dentro
Post by Dentro »
A friend of mine had v3.1.8 on his disk. Just installed it and it works smoooooth on xp 64bit!!! My baby got back:-) So, I can always post v3.1.8 for download to those who are stuck if 3dconnexion don't show up with som older drivers in the archive...
tmacbriar
Post by tmacbriar »
Dentro
I would greatly appreciate a copy of 3.1.8 if possible. Any possibility you could make it available?
I don't see any usable drivers available for download on the 3Dconnexions site.
tmacbriar
Dentro
Post by Dentro »
Here U are:-)
Best Regards
Dentro
-- Edit [ngomes]
Removed link to download site since 3DxSoftware v. 3.2.2 is available in the Archive section of the download software page.
Hi tmacbriar,
Please refer to this post.
We apologise for any inconvinence this issue may have caused you.
tmacbriar
Post by tmacbriar »
Many thanks. I will be installing later today.
I appreciate the assistance.
tmacbriar
Gubi
Post by Gubi »
Is there some way to get the 3.1.8 without paying for it? (Allready used my one free download)...
3.2.2 doen't solve my problem with not being able to draw in "user" viewports.
Regards
Gubi
GTWillemsen
Post by GTWillemsen »
3.3.2. is available for download, is this version good for you?
Gubi
Post by Gubi »
No - that's the current release... Trust me, I started with that one, even before i knew something was wrong!
Regards
Gubi
Gubi
Post by Gubi »
3.1.8 Doesn't fix it!
Just tried it... No luck for me :(
Regards
Gubi
tmacbriar
Post by tmacbriar »
Version 3.2 of the driver is now available in the archive section of the download page. I have installed it and it works for me with SpaceExplorer, Max 9 64bit, XP 64bit.
tmacbriar
