I am having problems keeping my Button Configuration choices permently assigned.
With Inventor running and before opening any Inventor files the Button Configurations are as per what I have selected. As soon as I open any Inventor file the buttons automatically change BACK to the default "Zoom All" and "Inventor Panel Fn". Predictably when the Inventor file is closed the buttons again change back to what I had originally selected.
Button Configuration problems with Inventor
Re: Button Configuration problems with Inventor
Hi bjermy,
The Button Configuration feature is environment-dependant. In other words, when you change environments in Inventor, a new Button Configuration is loaded. You can customise all the configuration. Simply load the environment, open the "Button Configuration" panel and program the device buttons with the commands of your choice.
If, on the other hand, you are seeing a different behaviour, then let us know and we will take from there.
What you are observing is, in fact, a feature. The behaviour is by design.bjermy wrote:As soon as I open any Inventor file the buttons automatically change BACK to the default "Zoom All" and "Inventor Panel Fn".
If by "environment-dependant" you mean that I could assign different buttons during part, assembly and drawing mode that would be fancy if I could get it to work, however....
I still cannot get ANY Button changes to stick. When I change the button controls with a model open the buttons work fine until I close that model. When I then open another model the settings go back to "Zoom All" and "Inventor Panel Fn".
It must be able to remember something because with all models closed and Inventor still running it brings back the desired settings.
Cracked it. Must be my very simple brain working in a Monday fashion. "Inventor Panel Fn" IS the Button Configuration manger for each environment. With an open document run the "Inventor Panel Fn" and drag the required command onto the desired button. Open a part, assembly, sketch, drawing or similar and assign buttons for these "environments".
