Remove Frame Rate Cap?
pebengineering
Post by pebengineering »
Is it possible to remove the frame rate cap with this device? My monitor is 144Hz which is noticeably smoother when navigating around SolidWorks as compared to 60Hz, but it's only noticeable with the mouse. The frame rates seem to peg at 60fps using the spacemouse, regardless of the level of detail in the model. When I rotate the model with the mouse, the framerates rise proportional to the level of detail in the model. Even with some massive files, the Quadro P6000 can easily seem to drive above 200fps.
Re: Remove Frame Rate Cap?
Hi pebengineering,
the framerate comes directly from the device.Unfortunately there is no possibility to change it.
Hypersonic
Post by Hypersonic »
Many 2DMouse drivers feature adjustable polling rates, up to 1000hz. It would be nice to see this in future 3DConnexion products. VR standard is 90fps, so it would be nice to have all input devices be able to match this at least, if not 144hz.
