Hello to all!
I am new to this forum since my Space Navigator arrived yesterday. It works pretty well, but there is one big problem.
I use Autodesk Architectural Desktop, 2007 and SN is working pretty good but has no zoom function. Is there anyone using Space Navigator with ADT? Are there any Updates that will solve the problem? Am I doing something wrong or are there any switches that I didn´t find? It should be no problem for 3Dconnexion to get this function working in ADT, since this seem to work in othe CAD-applications without any problems.
Thanks for your answers in advice,
regards,
chris
Space Navigator and ADT 2007
WIN XP, ADT 2007-SP1
I also use ADT2007, ant it works OK (zooming, panning, spinning, ... everything). I only have this problem. But a solution is coming soon...
Configuration
Hi WVbesien!
What configuration did you choose? Standard, od did you make any changes? What firmware/driver is installed?
Chris
Chris
I have the latest 3Dconnexion driver.
To check this: go to the control panel and choose "tools" > "update wizard...".
I only made some small modifications (speed a bit higher, some axes reversed,...), but it should allready work without these modifications.
If the (new) drivers are installed, you should see a 3Dconnexion toolbar in ADT2007 with 6 buttons.
Willem
Willem
ADT 2007
Hello Willem!
I did install newest drivers yesterday, and I do have the toolbar with 5 (!) buttons in the menu, but in 3D-Mode ( real mode) I cannot zoom at all, all other functions work. Do you use the professional Navigator, or the standard personal edition? Maybe there are differences between the both!?.
Chris
Chris
Re: ADT 2007
Hi stutte,
Regarding the problem at hand, are you able to zoom using the demos shipped with 3DxWare (the device driver)? You will find them in the Start menu, Programs, 3Dconnexion, 3Dconnexion 3DxWare, Demos.
There are no difference in functionality between the Personal and Standard Edition of the SpaceNavigator. The difference is the license terms (Standard Edition is available for commercial use).stutte wrote:Maybe there are differences between the both!?.
ADT 2007
Hello again!
Thanks for your fast answers!
I made it even in ADT to zoom in the 3D-Mode, but only if I press the scroll wheel of my mouse. I thought zoom is available by lifting the SN-Knob up or pressing it down without using my mouse. Was that incorrect?
Thanks again,
chris
Thanks again,
chris
