Remote Desktop use of local Space Navigator
Re: Remote Desktop use of local Space Navigator
I've also added a global way to switch the way KB keys are sent.
This allows you to specify a mechanism that works with RDP for all keys and even user macros.
So you don't need to mess around with these Driver_* assignments in global.xml, base.xml, etc.
Surcouf
Post by Surcouf »
jwick wrote: Tue Jun 29, 2021 1:55 am Surcouf,
PM your file to me, so I can see what changes you made.
Jwick,
sorry can't PM yet. Any chance to activate this feature or mail to my provided address so I can response directly?
Thx
Surcouf wrote: Wed Jun 30, 2021 11:51 pm
Jwick,
Thx
Email sent
New file sent
FoxbatNL
Post by FoxbatNL »
Hi All,
Got the Space Navigator to work over Remote Desktop. Followed the instructions to update both machines via gpedit.msc (run as admin). Be sure to select 'Administrators and Users' for the appropriate properties as descibed in the instructions.
Took some effort to understand but 2 side buttons are working fine. Key commands can't be used, however CAD software commands (in my case SolidWorks) can be assigned via the 3DConnexion properties menu on the destination machine and work like a charm.
No lag experience on rotations experienced so far. Below post gave the correct direction to go about. @Weymouth has added informational pictures in this thread as well.
Running 3DxWare version 10.7.4
pockybum522 wrote: Mon Dec 21, 2020 9:49 am Here's what finally worked for me when I was in the same boat of it wouldn't show up in the RDP Local resources section no matter what I did.
It looks like a new windows update may have added a new item under RemoteFX USB Device Redirection. See below for modified instructions. Original instructions are not mine.
(Install the same version driver on the host and client PC. I used 64-bit fine.)
These settings need to be changed on both (host and client) systems.
RemoteFX does not work with the universal receiver. You need to connect your wireless device via cable.
Run gpedit.msc
In the group policy editor open
Computer Configuration ->
Administrative Templates ->
Windows Components ->
Remote Desktop Services ->
Remote Desktop Connection Client ->
Enable: "Allow RDP redirection of other supported RemoteFX USB devices "
THIS IS THE KICKER ====> And set USB redirection rights to "Administrators and Users"
Remote Desktop Session Host ->
Connections
Enable: "Allow user to connect remotely by using Remote Desktop Services ".
Device and Resource Redirection
Disable: "Do not allow supported Plug and Play device redirection".
Remote Session Environment ->
RemoteFX for Windows Server 2008
Enable: "Configure RemoteFX".
Now open the command prompt with administrative rights.
run "gpupdate /force"
Next restart the machine.
After the restart right click the RDP connection and press edit.
Go to the “Local Resources” tab
Click on “More” on the bottom of the window (section "Local devices and resources").
You should see "Other supported RemoteFX USB devices".
Open it - it shows the connected SpaceMouse device.
Activate the checkbox for the SpaceMouse device.
The device will be forwarded to your target system next time when you connect via RDP.
FoxbatNL
Post by FoxbatNL »
Hi All,
Run gpedit.msc
Connections
markus123
Post by markus123 »
I have the same issue: I use the Enterprise in a remote session, it works perfect, but the Esc/ Tab/ Shift/ Ctrl/ Alt/ Space keys don`t work.
jwick ... can u send me the edited base.xml, maybe it works with it?
Thank u very much for your help.
Best regards
markus123,
PM sent
markus123
Post by markus123 »
Thank you very much jwick!
Esc/ Shift/ Ctrl and Alt work great now!
But i`m still struggling with the Tab/ Space/ Enter and Delete key- they don`t work. Do u have an idea what could be wrong?
There is no equivalent Tab in the released driver. You have to wait for the next major release for fuller support.
Delete and Return can be added by editing that Base.xml.
Change
            <ActionID>KB_Enter</ActionID>
to
            <ActionID>Driver_KB_Return</ActionID>
and
            <ActionID>KB_Delete</ActionID>
to
            <ActionID>Driver_KB_Delete</ActionID>
You will find them in the ID_Standard_3D_Mouse, but you can just search for them.
apmik2
Post by apmik2 »
is there any info on when we can expect this new version? Tab, space and macro support is required for me and right now I am out of luck.
apmik2,
Install 10.8.3 (new as of a few days ago).
Add this bolded line to your %appdata%\3Dconnexion\3DxWare\cfg\Global.xml file:
<Global...>
<Settings>
<KMJMechanism>SendInput</KMJMechanism>
</Settings>
Let me know if it works for you for all macros and keyboard keys in the remote environment.
apmik2
Post by apmik2 »
after some quick testing it seems like it works, I will test it further in a few days. I just changed the line in Global.xml and all the keyboard inputs work. If anything happens or I have any problems I will let you know.
dogansur
Post by dogansur »
I am having the same issue you are with Virtualhere. Unfortunately, I have not found any resolve.
LinaClark
Post by LinaClark »
D_Roam wrote: Fri Jun 19, 2020 5:57 am Has anyone had success in getting the RemoteFX solution to work when the local (client) computer is running Windows 10 Home (not Pro)? I have Windows 10 Home on my home PC, so I can't open gpedit to enable Remote FX for RDP. I read some posts saying there are scripts to enable the correct settings, but it did not work for PCs running Windows 10 Home.
Has anyone gotten this to work? Greatly appreciate any help.
It's possible to setup remote desktop windows 10 home, but you'll have to work with libraries (Wrapper and RDP wrap). You'll have to download them from GitHub. Here's a step-by-step instructions https://www.helpwire.app/blog/remote-de ... s-10-home/
