I cant get this app get to work.
I cant see movements in the joystick control panel and i'm missing buttons in the change layout programm.
Wat could be the problem??
Did remove the pic, not needed anymore
I'm feeling stupid, tried everything but the right mouse button.RBC9 wrote:right clic on the "Bind To" List ...
context menu appears.
same on "Layout List" for add/remove layout.
The values do change in the edit layout screen.u say u cant see move in joystick ..
did values in the "edit layout" screen change when u move the device ?
is ur device in device manager see as "RBC9 ...." ?
But in the applications the movement is not smooth at all.
RBC9 is standing in the device manager.
P.S. cant you make a button for disabling led blinking on the device?
u r not stupid , i ve remove the add/del button and don t update the doc.Mike_B wrote:I'm feeling stupid, tried everything but the right mouse button.RBC9 wrote:right clic on the "Bind To" List ...
in all kind of app ?Mike_B wrote:The values do change in the edit layout screen.u say u cant see move in joystick ..
or in 3d ?
sorry if mistundersttod , but my english ...Mike_B wrote: P.S. cant you make a button for disabling led blinking on the device?
blinking should not be if u r not in the "Edit Layout" Screen.
if the led blink outside , there is problem.
have u "AutoSwitch" turn on, try off.
if it is , don t u put ur app in "app list" in multiple Layout ?
In 3d everything is running smooth, but in other apps it seems that the joystick calibration isn't correct. I have a fresh installed Windows XP professionell.in all kind of app ?
or in 3d ?
Well the blinking is only in edit mode, but i found it a bit annoying.
SpaceTravelers are just around the corner! :)
Hey there.
I have been following the thread for a while since I got my 8-button wonder and obviously I'm jealous of your joystick driver.
I wanted to show support and appreciation you have been putting in this, and to say there are a bunch of us from a neighboring forum who have been drooling about this thread for a while now.
Please let me/us know if there's anything you need to get this thing functional for the SpaceTraveler.
Also, to the moderators/staff, is there an official position by 3dC about joystick drivers? is this something we should expect to see incorporated in the main distribution anytime in the near future?
Thanks a bunch.
Thanks a bunch.
Now with even MORE degrees of freedom.
Re: SpaceTravelers are just around the corner! :)
as i say , me and english ... so ... if i understand .... some people who are sit in their sofa love to laugh about my little contribution.Mazcal wrote: I wanted to show support and appreciation you have been putting in this, and to say there are a bunch of us from a neighboring forum who have been drooling about this thread for a while now.
no comment.
Time ....Mazcal wrote: Please let me/us know if there's anything you need to get this thing functional for the SpaceTraveler.
and terminate the SpacePilot version.
btw, if u post VID/PID and the HID_Descriptor ... i could try between 2 episode of Rome
Edit :
ChangeLog 02-17 :
- Add "Comment" textbox for each bind ...
- "Should" support SpacePilot And SpaceTraveler Device
In "Edit Layout" , select your device.
Not complete , for test only.
ChangeLog 02-18 :
- Correction of HID_Descriptor for SpacePilot and SpaceTraveler
- Bug in RBC9-driver when a Feature request is send from 3DConnexion driver to device.
- Start Add for SpaceBall device
I have received my SpaceNavigator yesterday and was very disapointed to see that I could not use it with other applications.
My goal was to use it as a MIDI controller, and also it could not be used as a standard HID device.
BUT, I have googled and see this forum, have downloaded your diver, install it, set a layout : WONDERFULL !
It is not always available as a HID in Bidule (it appears but there is no value), but at least I can use it in my applications (and have made a MIDI converter VST, see the other post).
Thanks a lot !
Jean-Marc
Thanks a lot !
Jean-Marc
Thats the problem i think, i can't calibrate it.RBC9 wrote:did u calibrate joystick in GameControler Screen ?
The crosshair is standing in the left upper corner.
See the picture i added.
Yes tried it with the driver on and off.have u test it without "3DConnexion" driver running ?
That's also a solution.RBC9 wrote: u should not be so often in "edit layout" .... isnt it?
Happy that u found u solution.jean-marc wrote:Hi,
Thanks a lot !
Jean-Marc
The device is still avaible as a standart HID device and u can get value.
with my driver , the SpaceNav is see as a multi device.
it is call "usage" in HID standart.
usage 04 : joystick
usage 02 : mouse
usage 06 : Keyboard
usagepage 0c usage 01 : custom keyboard (for special key)
usage 08 : the original 3DConnexion device
so , i u want to read / get the value from the device , ur app have to connect to the device usage 08. (it s the way original 3DConnexion do)
is there only One Joystick in the game controler list ? .... it happens to me , that a "shadow" version appears in the first release. i add a "patch" on the original HID to hide it ... but may be ....Mike_B wrote:...
have a try to this.
- Stop 3dConn driver
- uninstall the RBC9-SpaceNav with control panel
- uninstall the Driver in device manager. (still this f*** bug , u have to "move" the device when u start "uninstall driver", if u dont dont , the screen keep freeze and waiiiiiiit
check the option "delete driver" when prompt during uninstal.
- go to ur windows/system32/drivers and delete rb9-spacenav.sys if still there
- go to ur windows/inf and delete rbc9-spacenav.inf if still present
unplug device , restart computer.
now download the last version
install
plug and install the driver
be sur to select "RBC9 SpaceNavigator MouJoyKey v2" in screen , may be there is a "ghost" version.
and , in the last day/week , i change the description of the device, so Windows may confuse.
last thing , when u go to joystick calibration , are u sure the layout is select ? don t u have autoswitch turn on and another laoyout as default ?
edit : another idea , b4 restart ur computer.
u can check and remove in device manager , the device that u no longer use.
At a command prompt, type the following command , and then press ENTER:
set devmgr_show_nonpresent_devices=1
Type the following command a command prompt, and then press ENTER:
start devmgmt.msc
Click Show hidden devices on the View menu in Device Managers before you can see devices that are not connected to the computer
Troubleshoot the devices and drivers in Device Manager
look in Keyboard , Mouse , and Game contoler to remove device that should not be ...
ChangeLog 02-18 :
- Modify Joystick "throttle" to "Slider 2" for Jean-Marc Accoustic module.
Since , no a lot of people use Joystick throttle for the moment ... doing something else if needed.
