Addin with tdxinput.dll Driver 3.3.6 broken 3.1.8 worked
cruzy
Post by cruzy »
Hi 3DConnexion Developer Support
I developed an VB 6.0 addin for AlphaCAM (from Planit Solutions www.planit.com) for the SpaceTraveler. This works great with the 3.1.8 driver and tdxinput.dll but after updating to 3.3.6 it doesn't recieve the sensor or keyboard inputs anymore. What has changed with the new versions so that this doesn't work anymore? Do I need to change my addin?
Here is a bit from my code:
Private WithEvents TDxDev As TDxInput.Device
Private WithEvents TDxSensor As TDxInput.Sensor
Private WithEvents TDxKeys As TDxInput.Keyboard
Dim Rot As TDxInput.AngleAxis
Dim Trans As TDxInput.Vector3D
Public Sub StartTDx()
Set TDxDev = New TDxInput.Device
Set TDxSensor = TDxDev.Sensor
Set TDxKeys = TDxDev.Keyboard
TDxDev.Connect
End Sub
Private Sub TDxSensor_SensorInput()
Set Rot = TDxSensor.Rotation()
Set Trans = TDxSensor.Translation()
With App.ActiveDrawing.CurrentViewWindow
If .CanRotateView Then
App.ActiveDrawing.ScreenUpdating = False
.SetRotationPoint True, 0, 0, 0
.ZoomOut ((-1) * Trans.Z)
.RotateViewX (Rot.Angle * Rot.x)
.RotateViewY (Rot.Angle * Rot.y * (-1))
.RotateViewZ (Rot.Angle * Rot.Z)
.TranslateView Trans.x * Trans.y * (-1)
App.ActiveDrawing.ScreenUpdating = True
'If the view can not rotate ignore rotation input to smoothen things out a little
Else
.TranslateView Trans.x * FctTrans, Trans.y * (-1)
End If
End If
End With
End Sub
Thank you for the help.
Regards
Thomas Gysi
Hi cruzy,
The code seems correct. It may be the way that is used elsewhere in your product.
There's a VB sample on our SDK page. See if it works for you with 3.3.6 and let us know.
cruzy
Post by cruzy »
OK I figured it out. It has something to do with my spalsh screen. Why does this have an effect? It used to work with the older 3.1.8 as well as 3.2.2 which I just downloaded form your site.
I just uncommented the showing of the splashscreen and now it works. We really want to use a splash screen though, so what can I do? I can see I'm not the only one with this problem....
Hi cruzy,
It is a bug in the TDxInput COM server.
Wait a few more days. The fix for this issue is included in the next update which will be made available soon (qualification is already complete).
cruzy
Post by cruzy »
OK, I can use the spalsh screen again (yeh! :-))
