Inventor & Spacepilot <Enter>
beefweasel
Post by beefweasel »
Is there any way of assigning one of the buttons to work as the Enter Key when using my space pilot with inventor 2008?
Charlie.
Sure, but it will take a little work on your part.
You need to edit the 3DxInventor.scg file (or one of your Inventor custom userXX.scg config files) with wordpad or another Unicode-capable editor.
Add the following line somewhere in the middle of the BUTTON_NUMBERS array:
{ UI_RETURN_KEY, "Return Key", 69 },
This will add a new "Return Key" option in the button comboboxes that you can now assign to any SP button.
beefweasel
Thanks for the reply.
Can you please tell me where I might find the 3DxInventor.scg file?
Typically: c:\program files\3Dconnexion\3dconnexion 3dxsoftware\3dxware\en_us\profiles\default
(US English installation via 3DxSoftware mega installer)
beefweasel
I have now found the .scg file, copied it to my desktop, opened it with wordpad and added the line as suggested.
Maybe this is a daft question but I presume it matters how the file is saved? If I save the file with wordpad it is no longer showing as a .scg file?
beefweasel
Anyone able to talk me through this please?
Fred
Post by Fred »
Did you try renaming the file by removing the .txt and change it back to .scg
(Don't forget to copy it back to the original location.)
beefweasel
woo hoo! success, thanks all.
