SpaceBall 5000
hodgey
SpaceBall 5000
Post by hodgey »
I have a Spaceball 5000, (USB).
The optional (removable) palm rest causes me problems when positioned under my palm (closest to my arm), and I find it difficult to use the spaceball without it due to it's weight (too light).
When I reverse the plam rest, the orientation automatically reverses due to Left versus Right. I also read this somewhere, when trying to figure out why, but there is no software setting (I can find) to change/reverse orientation.
How can I reverse the palm rest WITHOUT the orientation being automatically reversed?
Can I disable the internal sensor (magnetic?), via software settings?
I find no config or .ini file in Program Files>3dconnexion, so where and how would I do this?
Thanks for the help!
Bryan
Post by Bryan »
Dear Hodgey,
In our newer driver versions you can go into the 3Dconnexion Control Panel and under the 'Advanced Settings' Tab select the directions reversed that you want by placing a check next to that direction.
Sincerely,
Bryan
hodgey
Reply
Post by hodgey »
Thanks A Bunch!
