I just installed Blender 2.46, Space Navigator and put the 3DxNdofBlender.plug plugin into the Blender plugins directory. It worked out of the box - however - the rotation axes are reversed. If I want to turn the Blender cube right, it turns left and vises versa. The 3DConnexion test cube works fine. Is there a value somewhere I can change?
Thanks for your help!
Maity
Blender 2.46 rotations reversed
Hi Maity, unfortunately there's a bug in the current 2.46 release of blender, where RY is rotated in turntable mode. You should be able to reverse the axis using our driver panel. However, if you do that you're going to have a reversed axis in fly mode.
This is clearly a bug. We have fixed that internally and we are currently testing it. I can't comment when we are going to have a public build, but hopefully soon.
ettore pasquini
software engineer
3Dconnexion, inc.
software engineer
3Dconnexion, inc.
