Some doubts
drodrig
Some doubts
Post by drodrig »
I have just bought a SpaceExplorer to use it with Catia V5.
I would like to ask some questions;
- in the 3d connexion control panel in the "device configuration" i don't understand how the "speed" button, is it the same as the sensibility button in the SpaceExplorer?
What is the "calibrate" button for?
- In the "App configuration" i would like to know what is the "Dominant" mode. what is the difference.
- And in the "Button configuration" the default function for the "2D button" is "Normal View Header"?
Thank you very much,
Halcon
Post by Halcon »
You use Calibrate when your mouse is moving without being touched.
Dominant means that only one direction the mouse is moved to, is used. So if you push the mouse to one side and whirl it simultanously only the pushing is used.
