I am having a dissapointing performance when the SpaceNavigator is used with Adobe Photoshop CS4. The primary use is to move 2D images around (when zoomed in) as part of editing photograhic images. The movement in photosphop is not as smooth as it should be. I have made a few observations and listed them below, and added some system information.
3DxViewer (the bundled image viewer) works fine when viewing images, this has a very smooth movement.
Photoshop CS4 when used without SpaceNavigator has smooth movement of images; the 'hand' being used to drag the image around.
Photoshop CS4 with SpaceNavigator - movement of image NOT smooth, it is a little 'blocky' or choppy (as though the image cannot be redrawn quick enough). The result is usuable but dissapointing.
I have the very latest video card driver and 3Dconnextion driver.
Thanks for any suggestions.
3Dconnexion Devices
Device Type: SpaceNavigator
Release Version: 3.6.11
( Driver Version 6.6.4 )
Firmware Version 4.04
System Information
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, MMX, 3DNow (2 CPUs), ~3.0GHz
Memory: 3582MB RAM
Page File: 511MB used, 8534MB available
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Display Memory: 320.0 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Driver Version: 6.14.0011.8048 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/12/2008 14:54:00, 6148864 bytes
WHQL Logo'd: Yes
Photoshop CS4 2D performance issue with SpaceNavigator
same problem here....
unfortunately I can confirm the problem of VERY bucking movements in Photoshop CS4 with Space Navigator driver 3.6.11
I hope this will be fixed soon. Or is this just a config problem??
Any hints?
TIA,
daniel
Any hints?
TIA,
daniel
