SpaceNavigator not working in Maya2009
EquiGym
Post by EquiGym »
I'm having a problem getting my new SpaceNavigator to work in Maya2009
I have done a manual installation as per the readme.txt found in C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxMaya200964\
this is the output found in the script editor
// Error: Unable to dynamically load : C:/Apps/Autodesk/Maya2009/bin/plug-ins/3DxMaya.mll
// Error: //
// Error: (3DxMaya) //
// Warning: No Magellan device found. Start 3DxWare and then restart Maya
The device is working using sample programs found in the program folder; C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\ chicken.exe, cube3d.exe, jet.exe, & puzzle.exe
System: Windows Vista Ent x64
Thank you
Greg.
EquiGym
Problem Solved
Post by EquiGym »
I thought I had installed the 64 bit version of Maya.
That was not the case, I installed the 32 bit version.
I replaced the x64 plugin for the x86 version.
Problem Solved.
