spacenavigator PE button configuration for solidworks 2008
toolmaker
Post by toolmaker »
I just got my spacenavigator PE, witch i am going to use with solidworks 2008.
A problem with the button configuration brought me to this site.
When i dubble click the 3d connection icon, and select the button configuration tab, i can configure the left button and the right button
I set the left button to ( Zoom to fit )
I set the right button to ( Normal to )
Under options i have Automatically Save Configurations checked
When i create a part in SW everything works ok, but when i have saved my part, and close SW, and later re-open SW to continiu my part, the right button ( Normal to ) is not working.
When i go to the 3d connection icon, to check my settings, the right button field is blank.
So every time i restart SW i have to set it again, how come?
What am i doing wrong?
thanks Toolmaker
rstadie
Post by rstadie »
Hi Toolmaker,
Please verify that you have full access to the following registry-key:
HKEY_CURRENT_USER\Software\3Dconnexion\3Dconnexion Add-In for SolidWorks\
Robert Stadie
Are you changing the settings in the 3DxWare GUI or in the 3Dconnexion addin in SW?
toolmaker
space navigator button
Post by toolmaker »
Thanks for the reply's, because of pc problems I was not able to react sooner
I reinstalled XP and my space navigator 3 D mouse is working perfect now !!!
Thanks for the help,
Toolmaker
