Just upgraded to Snow Leopard and cannot zoom, pan or twist using Maya with my Space Navigator PE. Buttons work fine. Not sure what to do about this. The navigator icon still shows up in Maya, so its loading the driver.
Anyone??
Mike
Space Navigator, Mac OS Snow Leopard & Maya
maya Mac OS
i've just got my space explorer and i just cant get it wo work right with my MAC.
My O. S. Mac snow leopard, i've installed all my drivers 25 times in this day and i cant' still get it to work. The demos, the cube and the 3D Axis, work, but when i get to maya there is the 3dconnexion button on top but only the customized buttons work but the joystick doesn't work at all.
and i've allready installed the latest 3dmacware version
what do i need to do?
snow leopard
I just buy 3D connexion for laptop.
This one does not support Snow Leopard.
Even the demo did not work.
I feel really bad, because this is my birthday present.
Re: maya Mac OS
Hi guayabeiro,guayabeiro wrote:... but only the customized buttons work but the joystick doesn't work at all.
please check if you have these files in the Contents -> scripts -> startup subfolder of your Maya applications folder:
- 3DxCube.xpm
magellanButtonEditor.mel
MagellanStartup.mel
usersetup.mel*
- MagellanStartup
Re: snow leopard
Hi nanozen,nanozen wrote:I just buy 3D connexion for laptop.
What model of the 3D mouse did you purchase exactly? What is the serial number/PID number?
Is your OS running in 64bit mode? You can check this by opening the System profiler, then choosing "Software" on the left and check if "64-bit Kernel and Extensions" says "Yes".
There should be some kind of sticky which gives all steps to perform while trying to get the SpaceNavigator to work with Maya (2009 or otherwise) on OSX.
At the moment all the information is spread out over a bazillion posts, and that gets confusing.
My Maya 2009 is rather temperamental about accepting the SpaceNavigator input or not. Sometimes it works fine, but mostly it doesn't do anything.
I have tried typing "MagellanStartup;" in the MEL command line and while it does not give an error message, there is no console output either.
I have repeatedly installed the plugins again, through the 3DConnexxion configuration screen. This didn't help either.
Moving all the script files from Users>Shared>Autodesk>maya>scripts to Users>Shared>Autodesk>maya>2009>scripts didn't work either.
Now, after moving them back to their original position and starting Maya, it seems to work again. However, I have no hope for it to work consistently over another startup. What should be the correct way of setting up the SpaceNavigator? A large list of 'this is how it should be, and if it's not, you should try it before making another forum thread' would be great.
