3ds Max 2010 64 bit - not working
yakas
Post by yakas »
3ds Max 2010 64 bit
Not working with the Space Navigator
Program is not recognized in the 3dxconnections control panel
Fred
Post by Fred »
Go to add remove programs.
Select 3dconnexion
Perform a custom install
Uncheck 3ds Max 2010 32 bit plugin
You can uncheck addins you donot use just make sure you allow 3dxware.
If the above doesnt work try the manual install:
* Manual Installation
Copy the "3dxstd.dlu" file from "C:\Program Files\3Dconnexion\3Dconnexion Plug-in for 3ds max"
to the "stdplugs" sub-directory of 3dx max.
Copy "3DxStudio.chm" to the help sub-directory
If you are using 3ds max 5 and higher copy 3DxStudio.ms to the scripts\startup sub-directory.
That's all.
yakas
Post by yakas »
work like a charm
the second option
thanks so much
