I use Autocad 2010 with SpaceNavigator and I have run into the following issue:
-I select an object - line, polyline, block, whatever
-I then want to add another object to my selection, but this one is not in my current view
-I navigate with the SpaceNavigator (zoom, pan) to get to this second object
-the first object I selected is not selected anymore.
Somehow the SpNav actions cancels the current selection. This behaviour doesn't happen in 3dsMax, for example, but I guess the API is not the same.
Drivers & software are up2date, both for SpaceNavigator and Autocad.
Thank you for any input you might have on this matter,
I got mail today. This bug has a number. Great.
But nobody has solved it yet. Must be a very big problem that finding a solution takes almost a year already.
"I hope that they fix it soon" sounds a bit ironic, however, hope is the last to die.
