I'm running Windows natively on it's own SSD. The upper picture (first post) is while running in Windows. The LCD is scrambled right after the driver starts and pretty much 90% of the time. I've only owned it for about one month and it's been like this every day in both Windows (native) and macOS. I never had a problem with my SpacePilot Pro which I've used for years on the same machine.
I took your advice and removed the existing settings in Windows per your link. As soon as I re-started the driver this is what I get. The LCD only shows a small band about 1/4 inch at the bottom of the LCD.
I really don't think it's a problem with Windows as the same thing (scrambled LCD) happens in macOS. I'll add, there hasn't been one day since I've owned it that the LCD worked properly.
And yes, the SpaceMouse Enterprise is plugged directly into a USB port on the back of my machine. I learned that from using the SpacePilot Pro I've used for several years.
So... This is right after cleaning up the setting files.
For what it's worth. I've been using SpaceBalls for around 30 years. This was the first one I used in 1988...
