Rotation On/Off button not re-enabling in Catia V5
AAnchan
Post by AAnchan »
1. I set both "pan/zoom" and "rotation" to enabled in the advanced settings of the driver
2. in Catia V5, I disable the "rotation" --> the rotation is disabled as expected
3. I push the button again to enable rotation --> nothing happens, the rotation stays disabled
4. the only way i can re-enable rotation is through the advanced settings of the driver
5. works fine in Java Platform of Enovia VPM
3DxWare 10.6.3
3DxWinCore 17.6.3.16588
This issue is the same as Soild Works. Can I use the same solution?
Re: Rotation On/Off button not re-enabling in Catia V5
Hello AAnchan,
I have sent an email to you for further troubleshooting.
Bytezero
Post by Bytezero »
I'm also having this same issue with the rotation on/off button not re-enabling in Catia V5. Has there been a solution found for this problem?
Well, what I noticed is that the SpaceMouse Enterprise device is sometimes displayed as SpacePilot PRO in CATIA v5-6R2018, it's a bit confusing...
