SpacePilot buttons do not work propperly in I-DEAS 12m3
mattias_n
Post by mattias_n »
Hello
If i use the standard profile for i-deas and have a shaded model and click on button 4 the model turns in to line mode butt if i pick button 3 to revert to shaded mode it doesn't work. All other buttons seems work ok.
I have attached a log file
11:13:16.325: 3DxWare driver startup: 2/1/2007 11:13:16
11:13:16.325: 3DxWare Driver Version 6.0.18 : December 5, 2006
11:13:16.325: -quiet -- disabled
11:13:16.325: -shutdown -- disabled
11:13:16.325: -protocol -- none given. All protocols enabled.
11:13:16.325: -com -- Disabled, using spcware.ini file settings.
11:13:16.325: -dev -- Disabled, using spcware.ini settings.
11:13:16.325: -eps disabled sending each event.
11:13:16.325: -log enabled
11:13:16.325: -logLevel ffffffff
11:13:16.325: -logFile C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\3DxWare.log
11:13:16.325: -searchWarnDlg enabled
11:13:16.325: -showGUI not enabled
11:13:16.325: -hideGUI not enabled
11:13:16.325: UdCtl: Attempting to find (ID=1053) 'Swedish' locale in SV_SW
11:13:16.325: UdCtl: Found resource DLL in C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\3dxsrv.dll
11:13:16.341: UdCtl: initialization successful.
11:13:16.341: UdCtl: Attempting to open Any Device (-1) on USB.
11:13:16.341: UdCtl: Attempting to load device DLL: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdDev\HIDDev.dll
11:13:16.356: UdDev: Attempting to open 3Dx-supported HID device on USB
11:13:16.372: UdDev: Beeping the device
11:13:16.372: UdDev: SpacePilot opened
11:13:16.372: UdCtl: Using device layer Any Supported 3Dconnexion USB Device supporting 0x22208050
11:13:16.372: UdCtl: Device 0 (Any Device(-1) on USB) -- enabled.
11:13:16.372: Device Type: 29
Num Buttons: 21
Num DOF: 6
CanBeep: 1
Device Name: SpacePilot
Port Name: USB
Firmware: HID Firmware Version 3.12
Version 3.12
Orientation 0
11:13:16.372: UdCtl: Attempting to load UI DLL: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdUi\udui.dll
11:13:16.388: UdUi->InitDLL: UI DLL Initializing
11:13:16.466: CUduiApp::FindDefaultConfig: Could not find a better config. Defaulting to any.scg
11:13:16.466: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg
11:13:16.497: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg
11:13:16.513: UdUi->SetOrientation: About to create windows.
11:13:17.106: SetOrientation: B4 ResetAppNameBox call
11:13:17.106: 11:13:17.106: SetOrientation: After ResetAppNameBox call
11:13:17.153: UdUi->SetOrientation: Windows Created.
11:13:17.153: UdCtl: UI (3DxWare UI v3.0) initialized.
11:13:17.153: UdCtl: Attempting to load transport DLL C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdTrans\kbdtrans.dll.
11:13:17.153: kbdtrans: Keyboard transport layer initialization
11:13:17.153: kbdtrans: Function table load successful
11:13:17.169: kbdtrans: Sendkey.dll successfully loaded.
11:13:17.169: UdCtl: Transport DLL: kbdtrans.dll -- enabled
11:13:17.169: Name: Window Keypress 1.0
11:13:17.169: Protocol ID: 50
11:13:17.169: Event Mask: 0x100
11:13:17.169: UdCtl: Attempting to load transport DLL C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdTrans\mwmtrans.dll.
11:13:17.169: mwmtranslog - Messages were registered
11:13:17.184: mwmtranslog - Opened hidden window
11:13:17.184: Mwmtrans: Username: conex1
11:13:17.184: mwmtrans.dll:UdTransInit: NOT Terminal Services Environment
11:13:17.184: mwmtrans: MagellanRPCServerInterface: endpoint is Magellan3DController
11:13:17.184: UdCtl: Transport DLL: mwmtrans.dll -- enabled
11:13:17.184: Name: Windows Messaging
11:13:17.184: Protocol ID: 10
11:13:17.184: Event Mask: 0x76
11:13:17.184: UdCtl: Attempting to load transport DLL C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdTrans\pxytrans.dll.
11:13:17.184: Loading Proxy DLLs
11:13:17.184: UdCtl: Transport DLL: pxytrans.dll -- enabled
11:13:17.184: Name: Proxy
11:13:17.184: Protocol ID: 5
11:13:17.200: UdCtl: Attempting to load transport DLL C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdTrans\s80trans.dll.
11:13:17.200: s80trans: SpaceWare 8.0 transport layer initialization
11:13:17.200: s80trans: Function table load successful
11:13:17.200: s80trans: Memory map loaded successfully
11:13:17.200: UdCtl: Transport DLL: s80trans.dll -- enabled
11:13:17.200: Name: SpaceWare 8.0
11:13:17.200: Protocol ID: 30
11:13:17.200: Event Mask: 0x76
11:13:17.200: UdCtl: numWaitHdls: 2 numTransHdls: 1 numDevHdls: 1
11:13:17.231: UdCtl: udfenNT.dll loaded sucessfully
11:13:24.857: mwmtranslog - App sends us its handle under command event
11:13:24.857: UdCtl: Protocol 10 request to open connection for hwnd 0xf051c.
11:13:24.857: UdCtl: App transport list: 11:13:24.857: 50 11:13:24.857: 10 11:13:24.857:
11:13:24.857: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg
11:13:24.873: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg
11:13:24.966: UdArbitrate: New Target: hWnd: 0xf051c, Class Name: I-DEAS Graphics Child, AppName (SiOpen): Unknown, ExeName: ideast.exe
11:13:24.966: UdCtl: Open accepted on protocol 10 for application: Unknown(ideast.exe)
11:13:24.966: mwmtranslog - AppStarts Event Called
11:13:24.966: mwmtranslog - App requested beep
11:13:29.670: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg
11:13:29.686: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\any.scg
11:13:29.779: UdCtl: Closed application Unknown on protocol 0.
11:13:29.779: kbdtrans: UdTransClose request made
11:13:29.779: UdCtl: Closed application Unknown on protocol 50.
11:13:29.779: UdCtl: Closed application Unknown on protocol 10.
11:13:31.186: mwmtranslog - App sends us its handle under command event
11:13:31.186: UdCtl: Protocol 10 request to open connection for hwnd 0xa0532.
11:13:31.186: UdCtl: App transport list: 11:13:31.186: 50 11:13:31.186: 10 11:13:31.186:
11:13:31.186: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\ideas.scg
11:13:31.201: UdUi:TlReadConfigFile: Reading file: C:\Program\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\default\ideas.scg
11:13:31.311: UdArbitrate: New Target: hWnd: 0xa0532, Class Name: I-DEAS Graphics Child, AppName (SiOpen): Unknown, ExeName: geomod.exe
11:13:31.311: UdCtl: Open accepted on protocol 10 for application: Unknown(geomod.exe)
11:13:31.311: mwmtranslog - AppStarts Event Called
11:13:31.311: mwmtranslog - App requested beep
11:13:45.280: kbtrans:UdTransSendEvent: Using macroMechanism = 0
11:13:48.405: kbtrans:UdTransSendEvent: Using macroMechanism = 0
agoenczi
User
User
SpacePilot buttons do not work propperly in I-DEAS 12m3Hi ma
Post by agoenczi »
Hi mattias_n
Sorry for the inconvenience. We are just analysing your log.
Hi mattias_n,
Those buttons run keyboard macros (they do the same thing you do when you type in the commands on the keyboard). Since we don't have a Swedish configuration file, the driver is defaulting to the English macros. It could be that the English macros don't work in the Swedish version of I-DEAS, or that they are not correct for your version of I-DEAS.
Please open the macro editor by selecting Custom Functions in the Button Configuration tab of the 3DxWare GUI. Edit the shade macro to see if it is doing the same thing that you have to do on the keyboard. Change it if required.
Please report back here so others will know that it may have to be changed.
Thanks.
3Dx Software Development
mattias_n
Post by mattias_n »
Hello
There is no swedish version of I-DEAS so I'm using the english version.
I'm using I-DEAS 12m3 on swedish Win XP SP2.
To get shaded hardware in I-DEAS I have to add this in the macro editor:
/do so; ; dt shh appl canc RETURN
This is a pain because i can't copy this from the programfile I have to create in I-DEAS to get the command. I-DEAS have very few keyboard accelerators.
It would be nice if could get a standard profile that works from UGS because this will give new users a chance to enjoy the 3d-controller. I have users that think the controller is use less because the buttons don't work.
I installed the new driver 3.1.8 today and uninstalled the old one first.
All the modifications i have made in my own profile was removed and my profile looked like the one provided by the driver so I had to recreate every thing again. Is this normal behavior?
Regards
Mattias N/
Hi mattias_n,
The installation of the new driver will not remove your saved configurations. You may though have to go into the driver GUI and reselect your saved configuration.
You should be able to share your configurations with your users. They are just files. They can be copied around.
mattias_n
Post by mattias_n »
Hello
It was my profile that was destoyed. I have 2 profiles one that come whit the drive and one that i have created and now both is looks the same.
I know that I an share the profile.
Hmmm. That might be possible in the following scenario:
A) Load the default configuration, make some change.
B) Those changes get auto-saved under "IDEAS-username"
C) Reload the default profile for any reason, say with the config button, and make some change. It will probably auto-save your new most recent changes over the top of your old changes.
It is simple to avoid this: just name your configuration yourself, don't rely on auto-saving it under IDEAS-username.
Sorry for all the trouble.
