Spacemouse Enterprise - problems with driver
I recently purchased a Spacemouse Enterprise and have barely made it work with Autodesk Maya and it doesn't work with Photoshop. With autocad it works fine however.
1) It works with Maya but I have to load the driver manually everytime I restart it. Activating auto-load in settings doesn't do it.
2) I can not make it work with Photoshop and have no clue as to how. I have tried to reinstall the driver several times with no luck. Is there a manual way to do it?
Thanks in advance,
Thanks in advance,
Re: Spacemouse Enterprise - problems with driver
hello,
for maya i have no idea , but in Photoshop there you have to define a shortcut for the spacemouse to work correctly , under the "new" shortcut editor and look there (i try to remember) automatisations and 3dconexion , use there a shortcut what isnt in use , it took me quite a moment to find something what isnt allready in use THAT i remember
i just checked again ... Menue ---> Edit ---> Keybordshortcuts ---> "Expand the Category" File ---> "Search for" Automatisation and "Expand this subcategory" ----> "Find there" 3DxPhotoshop ---> Define there a Keyboradshortcut ... i used here "Shift+Ctrl+P"
then it should work , on my end its working fine, i dont use the 3D mouse not to much for Photoshop i have a drawing tablett , but this was the way i made it work with 3D space mouse in Photoshop ... as fare i remember normaly there pops up also a little manual when starting photoshop when the keyboard shortcut isnt defined correctly ...
I hope this helps and sorry for my english
Greetings
Greetings
Lieber von Rembrandt gemalt, als vom Leben gezeichnet!
Sprachen/Languages/Idiomas: Deutsch/English/Español
Thank you, Nonny3D - it solved my Photoshop problem
Is anyone having issues with driver v10-7-0_r3248 or Photoshop 2021? My Spacemouse works with Fusion 360 and other apps. But at some point, Photoshop stopped working. I checked my shortcut key under Automation and "3Dxware" is gone.
I know this option was viable & was working in September, but I can't fix this even if I clean all my old 3Dconnexion settings found here: https://3dconnexion.com/at/support/faq/ ... n-windows/
Probably you have to uninstall and reinstall 3DxWare 10.7.0 to try it out.DHoude wrote: ↑Wed Nov 11, 2020 3:41 pm Is anyone having issues with driver v10-7-0_r3248 or Photoshop 2021? My Spacemouse works with Fusion 360 and other apps. But at some point, Photoshop stopped working. I checked my shortcut key under Automation and "3Dxware" is gone.
Thanks, yeah that is what I mean by the clean. But I uninstall the driver. Restarted Windows. Then did all the cleanup steps (including registry). Then I reinstalled the 1.7 driver. Same results.
on the 1.7 driver install, I do see the checkbox for the Photoshop plugin. But it seems like it is just not installing or is going to the wrong location (like a different Photoshop directory)
I think I might try 1.6.8 or something because I found this very handy when it was working.
Sorry, the old version that I am 100% sure worked was 10.6.9. I did the uninstall on 10.7.0. Restart and then the cleanup. The mouse works with the demo, but the Photoshop plugin is missing from the Keyboard Shortcuts Automate menu. I really feel like this is a difference in Photoshop 2021. I just don't know how I prove it.
Start a technical support ticket asking for trouble-shooting.DHoude wrote: ↑Thu Nov 12, 2020 6:23 am Sorry, the old version that I am 100% sure worked was 10.6.9. I did the uninstall on 10.7.0. Restart and then the cleanup. The mouse works with the demo, but the Photoshop plugin is missing from the Keyboard Shortcuts Automate menu. I really feel like this is a difference in Photoshop 2021. I just don't know how I prove it.
Ok, Thanks!
Anyone looking at this, the 10.7.0 driver is not yet compatible with Photoshop 2021. I was told that something is in progress for the next driver release.
Hi Team, patiently waiting, but I tried 10.7.1 and still no luck. Are there any updates? Thanks to this Space mouse I really hate using Photoshop the old way
Hi DHoude,
we are tracking this issue with our internal bug number WIN-778. Should be available with the next driver version.
