BricsCAD is certified for the SpacePilot. When I press the SpacePilot 'Menu' button, options show up in BricsCAD to change a few options. I can't figure out how to now modify the buttons of the SpacePilot. When I access the SpacePilot's setting globally (outside of BricsCAD) I can't find a way to manually select a program that I then want to alter.
Is there a way to set custom buttons for BricsCAD on the SpacePilot?
How to set custom buttons for BricsCAD Pro
3ds Max 2025, GIGABYTE X570 AORUS x570 Motherboard, Ryzen 9 3950x, 128 GB G.SKILL Trident Z Neo DDR4, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Spacemouse Pro Wireless, Windows 11 Pro x64, Tri-Monitor
Re: How to set custom buttons for BricsCAD Pro
Hi RobH,
you can make the settings for a specific application when this application is running and detected by the driver. Which driver are you using for your legacy device?
