Hi all,
If I open the settings window from the 3Dconnexion Home window or in Fusion 360 the window is opening and closing again after 2 seconds. I already uninstalled the driver and reinstalled it. I installed the most recent driver. Any idea what I can do to correct this? I,m using Windows 10 professiona, thanks.
Cadmouse settings window only 2 seconds visible
Re: Cadmouse settings window only 2 seconds visible
Additional info :Windows Diagnostic Data viewer is reporting "3DxSmartUi stopped working"
So, I perfromed an uninstal according the guidelines at
https://3dconnexion.com/nl/support/faq/ ... r-windows/
Rebooted, reinstalled the driver and connected the Cadmouse. The Settings window is still disappearing after about 2 seconds.
I'm sorry, what is the meaning of RMA due?
Hello Jeu,
RMA means that your device is faulty and needs to be replaced. But your problem is not a problem with the device, but a software problem.
As you already cleaned the settings on your machine I recommend that you contact our Technical Support Team. They will collect dianostic files for analysis.
OK, I already contacted the support Team September 30 but I only received a few replies with the message that they will try to solve this as soon as possible. So I tried to find a solution myself. Thanks for replying.
Hello Jeu,
our team needs a 3DxDiag file. Please proceed as follows:
- Right click the 3Dconnexion icon in the system tray and select "Write Log file" (if it is not yet activated).
- Stop the driver (Windows -> Start -> All Apps -> 3Dconnexion -> Stop Driver).
- Next start the driver (Windows -> Start -> All Apps -> 3Dconnexion -> Start Driver).
- Open the the CadMouse Settings window. Note the time of your system and how you opened it.
- In case you get an error please make a screenshot.
- Press the Shift button and hold and right click the 3Dconnexion icon. Select "Run Diagnostics".
- In the window of the 3Dconnexion Diagnostics Tool click "Collect System Information ...".
- This will take a few minutes and at the end an Explorer window will open at %TEMP\3Dconnexion\3DxDiag. You will find there a zip file that you should either send to the Support Team or provide a location where it can be dowloaded in case it is too large to send via email.
Hi Uta,
I sent the requested data to the support team.
To do so I replied to one of the E-mails I received with the case number 3DCX-20200830-0003.
I included a link to download the file because it was too big to send via E-mail.
Jeu
Jeu
Hi Jeu,
the team received it. Thanks. You have a different case number now.
I will check with the team how to proceed. We need to ask the developers for help with the analysis.
Hi Uta.
OK, thanks.
OK, thanks.
