ZBrush Camera Resets when Undoing (ctrl+z)
Walross
Post by Walross »
Hello everyone,
Does anyone have any experience with the following issue, please?
While the SpaceMouse Enterprise is connected, when using ZBrush, pressing the CTRL+Z undo shortcut resets my camera every single time. It also happens half the time when switching between sub-division levels.
Disconnecting the SpaceMouse and rebooting, force closing all the 3Dconnexion services results in ZBrush working as it should again.
I'm using the latest SpaceMouse driver, and the latest ZBrush.
Thanks for any feedback.
Walross
Re: ZBrush Camera Resets when Undoing (ctrl+z)
Post by Walross »
I just realised my document size was too small after I reinstalled ZBrush. The pen display I use is 4k, and the document size needs to be much larger than default or else the rear clipping plane hides the model when you undo (CTRL+Z), or change the subdivision level.
