I recently received my Cadmouse, which I'm using with a MacBook Pro M1. The mouse works, and so does the driver. However, none of the driver's functionalities seem to be working. I can't remap buttons or anything. The middle button is set to 'Pan,' and I can't change it. The same goes for the Radial Menu button, which has 'fillet,' 'extrude,' 'joint,' and 'drivers preferences,' but I can't change this to anything else.
Is there any solution or workaround to this issue? Thanks.
Driver Not Working
