Hey there,
I've have a 2019 space mouse that I use with Sketch Up but I haven't used it in a couple months. I noticed that I'm not able to set my Zoom Direction while also setting individual movement directions to reverse in the 3Dconnexion settings. Each time reverse is chosen for a movement type, forward/backward zoom type is unclicked automatically. Anyone have suggestions?
Space Mouse Zoom Direction issue
Re: Space Mouse Zoom Direction issue
You are using the Zoom direction control inside our GUI?
It overwrites any changes you made and sets the Axes to its specification.
There are ways around that, but you need to edit XML files. The GUI is over limited use for this.
I see! I have the same problem. Thanks admin.
