How to stop Mouse moving when using Spacemouse
Owen
Post by Owen »
Whilst using the Spacemouse in Autodesk inventor (and anywhere else on my system) it moves the mouse as well as sending the intended input (ie. 3D rotation, scrolling etc.)
I don't want the mouse to move only the intended input
I have toggled Desktop mode on/off but that only meant that the mouse would still move but rotation wouldn't happen
I have also attempted disabling devices under the 3Dconnexion KMJ emulator, but this has changed nothing.
Can anyone think of anything that might fix this?
Thanks in advance
- Owen
Re: How to stop Mouse moving when using Spacemouse
Have you been editing XML files outside of %appdata%\3Dconnexion\3DxWare\Cfg?
Please zip up all the files in that directory and email/PM them to me? If you can't email/PM (new user), post a link to them here.
Owen
Post by Owen »
Here is a link to the cfg files:
link to user files removed
I have been editing files in the cfg folder (as far I remember only to adjust delays on commands and to link a button to the desktop mode toggle when I was seeing if that was the problem), but I was wondering Is there a place that explains their structure/syntax? Because I don't really understand them currently.
Owen
Post by Owen »
I seem to have found the solution
After discovering that the mouse was still being controlled even when 3DxWare was not running, I assumed that it must be some other piece of software that was causing the issue.
That lead me to this reddit thread:
https://www.reddit.com/r/AlienwareAlpha ... ng_like_a/
And the solution that worked for me was this post:
https://www.reddit.com/r/AlienwareAlpha ... nt/ikpq1nj
tl;dr
Steam was trying to convert inputs from the SpaceMouse (what it was reading as a games controller) into regular keyboard and mouse inputs, which could be disabled for the SpaceMouse from the steam settings.
