Not sure if this is Creo 2.0 or a hardware based limitation, but complex movements, such as rotating at the same time as rolling.
Right now it "jumps" between the two if you try and do them at the same time. So I have to rotate then roll to get the desired orientaion.
Brian
Complex Movements
Re: Complex Movements
Dear brplatz,
You may have your 'Dominant' Mode enabled.
See what results you get if you disable it.
Start
All Programs
3Dconnexion Control Panel
'App Configuration' Tab
Uncheck 'Dominant'
Sincerely,
Bryan
Start
All Programs
Uncheck 'Dominant'
Sincerely,
Bryan
Wow I feel stupid now!
I knew that it couldnt be correct.
Thanks a ton! Wow this thing is 100x better!
