WHERE ARE THE PREVIOUS VERSIONS OF THE DRIVERS?
Re: WHERE ARE THE PREVIOUS VERSIONS OF THE DRIVERS?
Check the box "show archive" on the driver download page. There is usually the last driver before the current driver.
except for the Spacemouse wireless driver your limited to the current driver or you can choose another device and use the 3.17.8. driver. Installing this driver you'll lose the radial menu's they are not part of the 3Dxware driver in 3.17.8. only in the Driver 10 version.
Nah, I need ones going back to 2012 from when I first purchased the mouse. These new drivers don't work properly.
Hello kurtnelle -
The difference between the 2012 driver and Release 3.16.3 from 03/28/2013 on the downloads page is the addition of the 2014 add-ins. The 2012 version does not contain support for current applications so it is no longer in use. Checking the 'Also show archived software' box on the downloads page will display Release 3.16.3.
The clean install steps here will remove components of previous versions that could be causing problems. If you are still seeing a problem after using those steps , please let us know any error messages and the applications you are using.
Barbara
Barbara
Hello kurtnelle,kurtnelle wrote:Nah, I need ones going back to 2012 from when I first purchased the mouse. These new drivers don't work properly.
let us know what problem you have with the latest drivers. We might be able to provide a solution.
It is obvious that a 2012 driver would not contain support for 2014 applications. The problem is the assumption that everyone is using the latest version of software, with the latest mice and latest OS.Barbara wrote:The 2012 version does not contain support for current applications so it is no longer in use.
I am still running WindowsXP64 and 3dsMax 2009 with a Spaceball5000. I have no desire to upgrade, because the custom plugins that I use were written for 3dsMax2009, some of which were never rewritten for later releases.
If this machine ever explodes, I can restore my XP64 and 3dsMax from the original install discs.
I still have the install disc for my mouse, but it was bought in 2006...
3dconnexion's current 'archive' scheme makes it impossible for me or anyone to ever regain vintage installers.
Tehrasha
Spaceball 5000 driver is still listed under Old products. 3.7.22
I believe this driver still had the 3dxmax 8 add-in.
If you need a driver earlier you can choose the Spaceball 5000 serial driver December 2006
I wanted to test out that an earlier version of the driver has no problems. In August 2013 I was using the system extensively and had no problems. Since then, I had to reinstall the OS but I deleted the driver by mistake. Thinking that the new driver would "just work" like the old driver. That didn't happen. Yesterday I had a hunch and installed the Logitech Set Point drivers (for my 2d mouse). So far no issues. I suspect that the drivers are fighting for the attention of Inventor, and are stepping on each other's foot.
I can quicker live without SetPoint than 3DConnexion.
And the problem has returned.
And what exactly is the problem?
Same as others have reported here; when the constraints, measurement or other window is open in Inventor, the mouse stops responding for a minute then comes back.
Also have same problem here....Need some suggestion
note that we currently have a problem with 3DxWare 10 and Inventor. We are tracking the issue internally with bug number #6629.
Until we can release the fix for this issue I can recommend two workarounds:
1. If you click into the graphical window with the mouse the navigation is enabled again.
2. Alternatively you can install the driver for the SpaceMouse Pro, 3DxSoftware 3.17.8. It supports the SpaceMouse Wireless and the SpaceNavigator, too. But you do not have the Radial Menus with this driver version. The issue you reported does NOT occur with 3DxSoftware 3.17.x and Inventor.
So far the SpaceMouse Pro, 3DxSoftware 3.17.8 driver is working. I'm happy again. Uploading that driver to the cloud so I never loose it again.
Where can I download version 3.17.8 ?
