Max Speed
PaulGee
Max Speed
Post by PaulGee »
Is there a way of finding out the current maximum value for vector3D object under the COM interface.
I just want a means of knowing for a particular direction what proportion of the maximum value I am.
Many thanks
Paul.
Hmmm, I'm not sure if this is possible. The rotation vector is normalised so its length is always 1 but the translation vector is in arbitrary units and they vary with the speed setting in the driver.
What are you trying to achieve? Perhaps there is a different approach to consider.
PaulGee
Post by PaulGee »
What I was trying to achieve was a proportional directional control where the amount of force in a certain direction is a percentage of the total force that can be exerted.
I've now sorted a routine to do this, it required a change of thinking on my behalf. Rather than trying to find the max value of the device depending on the speed setting, I have an arbitrary value and use the vector components as measure of how quickly the max value is reached. So on a high speed setting little force is required to reach 100%, where as on slow setting more force is required to reach the maximum but you have more control.
Hope that makes some kind of sensor and is useful for others.
