Using MODO 801 SP2 and Space Navigator, the process "3DxVirtualLCD" uses over 90% CPU.
What is the purpose of it? I can't find any information about it anywhere, except that it's something to do with Space Mouse Pro.
If I kill the process, everything seems to work ok. Assuming it's not needed, how can I disable it permanently?
3DxVirtualLCD using >90% CPU
Re: 3DxVirtualLCD using >90% CPU
Hi sumguy,
yes, this is a feature for the SpaceMouse Pro. Of course it should not take 90% of your CPU. It usually doesn't do that.
As you are using a SpaceNavigator you can just delete the 3DxVirtualLCD.exe from the installation folder of 3DxWare. The path is C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64.
I'm using Mac OS X...
Hi UtaSH,
how can I disable 3DxVirtualLCD on Mac OS X?
Hi sumguy,
yes, sorry. Mac OS X.
Which driver version is installed?
Which hardware do you have?
3DxWare 10.2.0 (also tried it with the previous version, same problem)
SpaceNavigator NB, Firmware 4.35
OS X 10.9.4
OS X 10.9.4
