tmacbriar
Posts: 6 Joined: Tue May 08, 2007 12:32 pm
Post
by tmacbriar » Tue May 08, 2007 1:05 pm
Can a functioning older driver be made available for 3DSMax9 64bit, as the current driver available for download is not functional? I have just purchased SpaceExplorer, so I have no previous drivers.
znissan
User
Posts: 191 Joined: Tue Nov 28, 2006 12:32 pm
Post
by znissan » Tue May 08, 2007 8:42 pm
Hello:
Could you please post this question in the Windows forum so that the right support people and also others will be able to view it?
Ziva Nissan
3Dconnexion, Inc.
Posts: 3347 Joined: Mon Nov 27, 2006 7:22 am
Post
by ngomes » Wed May 09, 2007 1:11 am
Moved to Windows forum.
tmacbriar
Post
by tmacbriar » Sat May 12, 2007 1:08 pm
I was hoping that someone would be able to post a previous driver to use until the new driver (2 to 3 weeks) becomes available. I sure would like to be able to use this piece of equipment after purchasing it in good faith to use with 3DS Max 9.
Dentro
Posts: 8 Joined: Thu May 10, 2007 12:11 pm
Post
by Dentro » Mon May 14, 2007 3:27 am
A friend of mine had v3.1.8 on his disk. Just installed it and it works smoooooth on xp 64bit!!! My baby got back:-) So, I can always post v3.1.8 for download to those who are stuck if 3dconnexion don't show up with som older drivers in the archive...
tmacbriar
Post
by tmacbriar » Mon May 14, 2007 8:45 am
Dentro
I would greatly appreciate a copy of 3.1.8 if possible. Any possibility you could make it available?
I don't see any usable drivers available for download on the 3Dconnexions site.
Dentro
Post
by Dentro » Mon May 14, 2007 4:08 pm
Here U are:-)
Best Regards
Dentro
-- Edit [ngomes]
Removed link to download site since 3DxSoftware v. 3.2.2 is available in the Archive section of the download software
page .
Post
by ngomes » Tue May 15, 2007 3:07 am
Hi tmacbriar,
Please refer to this
post .
We apologise for any inconvinence this issue may have caused you.
tmacbriar
Post
by tmacbriar » Tue May 15, 2007 7:28 am
Many thanks. I will be installing later today.
I appreciate the assistance.
Gubi
Posts: 7 Joined: Fri May 18, 2007 5:46 pm
Post
by Gubi » Fri May 18, 2007 6:48 pm
Is there some way to get the 3.1.8 without paying for it? (Allready used my one free download)...
3.2.2 doen't solve my problem with not being able to draw in "user" viewports.
Regards
Gubi
GTWillemsen
Posts: 33 Joined: Sat Mar 24, 2007 7:31 am
Post
by GTWillemsen » Sat May 19, 2007 1:17 am
3.3.2. is available for download, is this version good for you?
Gubi
Post
by Gubi » Sat May 19, 2007 2:59 am
No - that's the current release... Trust me, I started with that one, even before i knew something was wrong!
Regards
Gubi
Gubi
Post
by Gubi » Sat May 19, 2007 3:20 am
3.1.8 Doesn't fix it!
Just tried it... No luck for me
Regards
Gubi
tmacbriar
Post
by tmacbriar » Sat May 19, 2007 8:50 am
Version 3.2 of the driver is now available in the archive section of the download page. I have installed it and it works for me with SpaceExplorer, Max 9 64bit, XP 64bit.
