Space Navigator installing problem
Stan1
Post by Stan1 » Tue Apr 21, 2015 1:47 pm
Hi there,
So, installing last driver 1.8.0, everything fine. Next, after
/home/stan/3dxconnection/etc/3DxWare/daemon/3dxsrv -d usb
it says -
[2015-04-22 02:14:39] Error: Can't find any configuration files! Please reinstall you configurations in /etc/3DxWare properly!
Segmentation fault
Ok, changing permission on all 3DxWare files and dirs to rwxrwxrwx but nothing happens. Still got the same message.
so this is log file:
3DxWareUNIX V1.8.0 ID 10505 log file
Process ID: 3793
 Time: 2015-04-22 02:14:29
Machineinfo 1: Systemname=Linux, Nodename=localhost, Release=3.18.1-pclos1
Machineinfo 2: Version=#1 SMP Wed Dec 17 00:55:07 CST 2014, Machine=x86_64
Runlevel-Info:          уровень выполнения 5 2015-04-21 13:16                   предыдущий=S
[2015-04-22 02:14:29] uddev.c, 1060: UdDevInit() 0xa15010
[2015-04-22 02:14:29] 3dxsrv.c,806: displayname = :0.0
[2015-04-22 02:14:29] auth.c :: authGetUser(), FOUND: user = stan, id = :0, line = tty8, pid =    32568, host = :0, type = 7
[2015-04-22 02:14:29] auth.c :: authGetUser(), FOUND: user home = "/home/stan"
[2015-04-22 02:14:29] 3dxsrv.c :: startupCommandLine(), authGetUser(), user=stan
[2015-04-22 02:14:29] UdDev: Opening USB device on USB port /dev/bus/usb/003/002
[2015-04-22 02:14:29] UdDev: Opening SpaceNavigator on USB port /dev/bus/usb/003/002
[2015-04-22 02:14:29] snav_usb.c :: UdDevRezero(): Rezeroing the device
[2015-04-22 02:14:29] snav_usb.c :: UdDevSetDeadband(): Setting deadband to 26
[2015-04-22 02:14:29] 3dxsrv.c,831: UdDevOpen() was successful [SpaceNavigator]
PClinuxOS 2014.12
Kernel 3.18.1-pclos1
xcfe
What should I do?
Stan1
Re: Space Navigator installing problem
Post by Stan1 » Tue Apr 28, 2015 4:57 am
so, there is no tech support anymore, isn't it?
Tehrasha
Post by Tehrasha » Tue Apr 28, 2015 11:01 am
Are you launching the driver as root?
Stan1
Post by Stan1 » Tue Apr 28, 2015 1:21 pm
sure
Stan1
Post by Stan1 » Tue Apr 28, 2015 11:22 pm
have updated kernel to 3.19.5
same result
Post by UtaSH » Mon May 04, 2015 7:45 am
Hi Stan1,
sorry, but the path for the driver cannot be changed. You have to install it in /etc/3DxWare. (Or use at least softlinks to that path.)
Stan1
Post by Stan1 » Mon May 04, 2015 11:37 pm
Thanks,that wasn't obvious )
Now driver works, demo cube is moving\rotating fine, I can see configurator (but I didn't get how to start it, command or something), but it doesn't work in blender, zero reaction.
Should I change some kind of blender settings? Under windows it works without any changes
Stan1
Post by Stan1 » Tue May 05, 2015 11:07 pm
Seems there is an one reply per two weeks on this support forum)
ok, let's wait)
meanwhile I have got that driver panel starts automatically, but is it ok that you can't close demo cube window, kill process only?
blender 2.74 still doesn't know that I use a space navigator and I still wonder why...
Tehrasha
Post by Tehrasha » Wed May 06, 2015 12:21 am
Stan1 wrote:meanwhile I have got that driver panel starts automatically, but is it ok that you can't close demo cube window, kill process only?
Pressing escape does not exit the cube demo?
I have never had 3DxWare on Linux work with Blender. The old xDriver works with the older serial devices.
For linux Blender, I use the freeware driver spacenavd http://spacenav.sourceforge.net/
Stan1
Post by Stan1 » Wed May 06, 2015 12:32 am
Lol, it does, I ve tried to close it with window close button)
Thanks for that freeware driver, hope it is more simple in use than the original one.
Stan1
Post by Stan1 » Sat May 30, 2015 3:21 am
So official driver does not work in Blender at all, does it?
I have checked it in Ubuntu 15.04 with same result. That demos work perfectly but Blender does not see device at all.
Is there a way to make it work in Blender or the only solution is to use free driver?
freedriver works with Blender but has not got so many settings to set up
