So, installing last driver 1.8.0, everything fine. Next, after
/home/stan/3dxconnection/etc/3DxWare/daemon/3dxsrv -d usbCode: Select all
[2015-04-22 02:14:39] Error: Can't find any configuration files! Please reinstall you configurations in /etc/3DxWare properly!
Segmentation fault so this is log file:
3DxWareUNIX V1.8.0 ID 10505 log file
Process ID: 3793
Time: 2015-04-22 02:14:29
Machineinfo 1: Systemname=Linux, Nodename=localhost, Release=3.18.1-pclos1
Machineinfo 2: Version=#1 SMP Wed Dec 17 00:55:07 CST 2014, Machine=x86_64
Runlevel-Info: уровень выполнения 5 2015-04-21 13:16 предыдущий=S
[2015-04-22 02:14:29] uddev.c, 1060: UdDevInit() 0xa15010
[2015-04-22 02:14:29] 3dxsrv.c,806: displayname = :0.0
[2015-04-22 02:14:29] auth.c :: authGetUser(), FOUND: user = stan, id = :0, line = tty8, pid = 32568, host = :0, type = 7
[2015-04-22 02:14:29] auth.c :: authGetUser(), FOUND: user home = "/home/stan"
[2015-04-22 02:14:29] 3dxsrv.c :: startupCommandLine(), authGetUser(), user=stan
[2015-04-22 02:14:29] UdDev: Opening USB device on USB port /dev/bus/usb/003/002
[2015-04-22 02:14:29] UdDev: Opening SpaceNavigator on USB port /dev/bus/usb/003/002
[2015-04-22 02:14:29] snav_usb.c :: UdDevRezero(): Rezeroing the device
[2015-04-22 02:14:29] snav_usb.c :: UdDevSetDeadband(): Setting deadband to 26
[2015-04-22 02:14:29] 3dxsrv.c,831: UdDevOpen() was successful [SpaceNavigator]
Kernel 3.18.1-pclos1
xcfe
What should I do?
