3dconnexion still bugs up.
Tomludd
Post by Tomludd »
Do you have any other solution's?
--==Tomludd==--
Tomludd
Post by Tomludd »
this is the problem:
The Jet in Jet Demo Spin towards you, by just touching the SpaceNavigaor, and in every other application i use. javascript:emoticon('Crying or Very sad')
The spaceNavigator Pan right, Pan Down, Zoom Forward, and Spin right, at the same time, just by touching it. If i reverse all axes the result is the reverse...
It's doing it for 2 seconds even if i just have touched it for an half second.
I've tried to restore all defaults, and Calibrate, in all profiles
also i tried disconnecting it and connecting it in a other USB port and restarting the drivers.
Yester day it din't work, and i disconnected it many times and I made it work once but when i restarted my Computer to day it did'n work, anny more.
I tried it on a other computer and there it worked perfectly, but on my own computer it won't make anny god.
I have also updated the driver to:
Release Version 3.6.4
Driver version 6.6.1
Firmware Version 3.18
I use Windows Xp SP2 (32-bit x86)
Do you have anny solution for me Question
_________________
--==Tomludd==--
they godt this solution:
jwick wrote:I've seen this before. I can't recall exactly what it is. It is something simple though like 2 drivers running at once. While I am racking my brain, do the following:
Uninstall 3DxSoftware.
Delete siappdll.dll and spwini.dll from your System32 directory.
Delete the contents of HKCU/software/3dconnexion/3dxware/applications
Delete all your saved profiles in %appdata%/3dconnexion/3dxware/profiles.
Reboot.
Reinstall 3DxSoftware.
Jim
3Dx Software Development
but it did not work:
any other solutions?
--==Tomludd==--
rstadie
Post by rstadie »
Maybe you can use it some more time on the other computer and see if the problem is really not existent there.
Robert Stadie
Tomludd
Post by Tomludd »
my brother used it along time on the other computer and have never come over this problem(2-3 month)... the bug was on my own computer before and after he did borrow it from me.
--==Tomludd==--
rstadie
Post by rstadie »
Please run the "System Information" tool (msinfo32.exe), save the information to a file and send it to us. You will find the Email-address in your inbox.
Robert Stadie
rstadie
Post by rstadie »
You could try the following to find out what is causing this:
- Disable your NIC
- Uninstall any dongle-software
- Disable or uninstall Kaspersky and Anvir
Please also start the Cube demo, move around and see if you can see any process in task-manager that "responds" to the 3D Mouse. You can also check if some process is reacting (taskman) if you start/stop the driver.
Please let us know what happens.
Robert Stadie
Tomludd
Post by Tomludd »
reinstalled my computer and installed both kaspersky and anvir and they do not seem to have anny thing to do with the problem...
well my problem is solved but i do not know what was trubeling my spacenavigator...
--==Tomludd==--
Help me try to understand what you did:
1) You were having crazy movement from your SpaceNavigator.
2) You reinstalled your O/S, and Kaspersky and anvir and now the SpaceNavigator works correctly?
This would be consistent with an antivirus software conflict.
Jim
