Swap middle and right click on CadMouse on MacOS (All of them)
AttilaTheHunk
Post by AttilaTheHunk »
Hi everyone,
I have been looking for a way to swap middle and right click so I can keep right clicking with my middle finger like a civilised human :)
3Dconnexion support told me this is not possible in the Mac OS drivers for the mice at the moment and didn't know if it will be implemented.
Luckily there is a great app called Steermouse that lets you customise all buttons (and everything else mouse related).
It's 20 bucks for the license, but well worth it as it makes the great CadMouse series usable.
Link to the app here:
https://plentycom.jp/en/steermouse/
fx_justin
Re: Swap middle and right click on CadMouse on MacOS (All of them)
Post by fx_justin »
I was looking for a way to change the middle and right click buttons as well when I found your post. I downloaded steermouse, and it alerted me about a conflict with Karabiner-Elements, which is an excellent program that I have used for keyboard customizations. I never thought about using Karabiner-Elements for mouse customizations, but it turns out it has the ability to change mouse buttons and do other mouse and keyboard customizations. So if anyone is looking for another options, Karabiner-Elements also works well for this issue.
StefanV
Post by StefanV »
A native macos solution is now available: https://forum.3dconnexion.com/viewtopic ... 63#p125763
AmroSalih
Post by AmroSalih »
If the 3DxWare driver software is installed,
1. Open the 3Dconnexion Home menu > Properties.
2. Select your 3Dconnexion CADMouse from the device list.
3. Ensure that "Any application" is selected in the "Configure:" menu.
4. Open the "Buttons" tab and select your desired programable button from the list.
5. Adjust "Mapping" > "2D Mouse"
6. Set "Mouse action" > "Assign "Click Button 3"
StefanV
Post by StefanV »
What you are describing is for changing the behavior of the central button. You can’t change the assignment for the third physical button
AmroSalih
Post by AmroSalih »
True, macOS has the swap option available for the left and right mouse buttons.
