I've been using my SpaceMouse (Pro Wireless) for a while with a program and have recently changed to a different version of this program, but I want to use the same button/puck profile that I was using with the original app. I'm unable to open the original app so a simple screenshot + copy won't really work, and I can't remember the entire profile off the top of my head.
Is there a way for me to export a profile from an app that I'm no longer able to use, and import it to a different app? I thought to try editing the file resulting from "export settings" to change the name of the old app to the new app, but the .dxz file is encrypted
There's no direct way to do that. I like the idea though.
The file export package is just a zip file. You can open it with any zip understanding program (e.g., 7zip).
The settings for your old app will be on disk under %appdata%\3dconnexion\3Dxware\cfg\<probably the name of your application>.xml
If the saved settings are applicable in the new application, you can copy them over with any text editor (e.g., Notepad++).
If they are specific to the app, or use entries from a different default file, it will be more involved.
It might help to know what the two apps are, but, in general, this is the procedure:
I suggest you run the new program.
Save something using in our GUI, e.g., a button assignment.
This will write a new file for you that is appropriate for your new application.
After that, you can copy all the <ButtonActions> and <Devices> sections from the old XML file to the new XML file.
You might need to PM the files to me if that doesn't work so easily.
