SpaceMouse Blender behavior changed after 10.8.11 update
ArchVisKatie
Post by ArchVisKatie »
Similar to a previous post (https://forum.3dconnexion.com/viewtopic ... er#p110890), after the latest 3DConnexion software update (10.8.11.3519), my SpaceMouse no longer behaves properly in Blender.
The Tilt function (i.e. tilting the cap left/right, resulting in a Dutch angle viewport - outlined in RED, below) now spins on the Z axis.
The Rotate function (i.e. turning the cap left/right - outlined in YELLOW, below) now spins on the X/Y axis.
FYI: My Z axis in Blender is the vertical axis.
These two settings now are somehow switched (not reversed in direction, literally switched).
No matter how many settings I adjust, in the 3DConnexion software and/or in Blender's NDOF settings, I cannot get these two functions to work properly. This latest update has essentially rendered my SpaceMouse useless.
wrong rotations.jpg (74.28 KiB) Viewed 2560 times
ArchVisKatie
Re: SpaceMouse Blender behavior changed after 10.8.11 update
UPDATE: I re-downloaded last year's driver (2021) and software from the 3DConnexion site, uninstalled the new version and restarted my computer, then installed the old driver/software.
Things still didn't work properly, so I clicked "Reset All Settings" and that seemed to fix the issue. Somehow it seems that, despite uninstall/clean installation, there were some leftover 3DConnexion files somewhere hidden on my computer that were causing the mouse to use old settings.
Once I reset all settings, suddenly I had the rotate and tilt functions back again, without changing any other settings in Blender or the 3DConnexion software (i.e. no manual changes to the 3DConnexion software settings).
[email protected]
Post by [email protected] »
I met the same problem.
but I clicked reset all settings all in OK.
10.8.11.3519
