Hi everyone.
The follow buttons doesn't work properly on Archicad (23 and 20 version on MacOS 10.15 and 10.13).
The T button always show the 3D Settings Window, even if I put another macro or keystroke or when I disable it!
The R and F don't work at all when I assign them a macro or keystroke.
And the Menu button always fit to window my work (like the Fit button) even if I assign it another macro or keystroke.
All these buttons works fine on other apps.
Has anyone any of these problems with these 4 buttons?
Thank you in advance!
Buttons problems on Archicad - SpaceMousePro
Re: Buttons problems on Archicad - SpaceMousePro
Hi saposabio!
Have you solved this problem?
This is an old problem never solved.
It's always present now on AC 26 Silicon MAC.
We sent many messages without any answer and the problem is still there.
This is the link to the trend in the Graphisoft forum.
https://community.graphisoft.com/t5/Set ... d-p/291380
This is an old discussion without any answer on this forum:
https://forum.3dconnexion.com/viewtopic.php?t=39676
Dear 3dconnexion team, we spent money for a device that doesn't work on the software we are working on. It works on other softwares.
We don't want money back; we would like to have an answer to understand if this problem will be never solved.
Even if the problem is in Graphisoft, please try to find with them the solution.
Thank you.
Thank you.
Go with a mobile workstation that runs Windows OS.
