New C4D plugin crashes the program often
antoniokriisp
Since updating to new cinema4d plugin I've experienced crashes constantly. They happen when I move the puck.
Is this a known issue, are you working on a solution?
Anyone else experiencing this?
I did the usual stuff, reinstalling cinema and 3Dconnexion drivers.
Using latest version of cinema and drivers.
Best regards,
Antonio
Best regards,
Antonio
Re: New C4D plugin crashes the program often
Roll back to the previous stable version.
Same problem here. Windows 11, C4D 2023.2 3dconnexion 8.1.12. C4D crashes when moving the navigation button. C4D support:
Cinema 4D Technical Support (Maxon Support)
You forwarded a bugreport to us on 2023/04/07.
The crash was caused by your currently installed driver from 3Dconnexion.
Please install the latest drivers from 3Dconnexions homepage or try to remove the driver completely to avoid further crashes.
Why was there no testing before release? Besides, the new connexion driver not only causes crashes, you can use the device only to navigate in the scene, you cannot move the objects any more.
Very disappointing.
Very disappointing.
antoniokriisp
3D connexion support, any reply on this issue?
antoniokriisp
We are aware of these reports but we haven't been able to reproduce the issue.antoniokriisp wrote: ↑Thu Apr 06, 2023 11:38 pm Since updating to new cinema4d plugin I've experienced crashes constantly. They happen when I move the puck.
Does the application always crash as soon as you move the SpaceMouse sensor cap or does it look random?
danhildebrand91
Can you reproduce this issue? I even included a video and scene file.
https://forum.3dconnexion.com/viewtopic ... 25&t=53202
It's pretty clear that the driver integration is severely lacking compared to performance with previous versions of C4D (the natively supported versions).
i tried your scene in latest cinema it seems fine and not laggy on my pc..
windows 11.
windows 11.
antoniokriisp
It's random. 10-20 times a day, different projects, different c4d environments (I think it likes to crash in uv-map workspace)ngomes wrote: ↑Mon Apr 17, 2023 6:23 amWe are aware of these reports but we haven't been able to reproduce the issue.antoniokriisp wrote: ↑Thu Apr 06, 2023 11:38 pm Since updating to new cinema4d plugin I've experienced crashes constantly. They happen when I move the puck.
antoniokriisp
Heh, just found out I can replicate the crash 100% of the time. I just open this scene, go to UV-edit workspace and move the puck, immediate crash.
link to the scene (11mb) https://drive.google.com/file/d/1fXJoIK ... share_link
Latest 3Dconnexion drivers, windows 10 fully updated, fresh windows installation.
antoniokriisp
Forgot to attach bug report https://drive.google.com/file/d/1JA9uHb ... share_link
This link does not seem to work: only allowed Google accounts can access the file.antoniokriisp wrote: ↑Tue Apr 18, 2023 12:35 am link to the scene (11mb) https://drive.google.com/file/d/1fXJoIK ... share_link
Perhaps you can send us a non-restricted link over PM in this Forum?
antoniokriisp
Thank you for providing the data. We tried to reproduce the crash but we couldn't.
If possible, please share your Cinema 4D preferences and the contents of the following directory (zip file):
%APPDATA%\3Dconnexion-
antoniokriisp
https://drive.google.com/file/d/1G-hN24 ... share_link
Here are the files.
I would load via recent-file menu.
Here are the files.
