I can't find a navlib.xml file in either the SDK package or in the folder in appdata. Where is it supposed to be?Copy the navlib.xml configuration file to %appdata%\3Dconnexion\3Dxware\Cfg to enable logging.
Navlib logging configuration?
JoelWilliamson
In the SDK docs (navlib.pdf), it says
Re: Navlib logging configuration?
I noticed that myself a few months ago. As far as I know, it is currently supposed to contain:
<?xml version="1.0" encoding="utf-8"?>
<Navlib>
<Settings>
<Logging>
<GetClient>true</GetClient>
<SetClient>true</SetClient>
<ReadValue>true</ReadValue>
<WriteValue>true</WriteValue>
</Logging>
<Probe>true</Probe>
</Settings>
</Navlib>-
JoelWilliamson
Thanks. I'll give that a try.
JoelWilliamson
17:04:16.552: Dumping accessors
property "coordinateSystem" fnGet=true fnPut=false param=0x0
property "active" fnGet=false fnPut=false param=0x0
property "events.keyRelease" fnGet=false fnPut=true param=0x0
property "settings" fnGet=false fnPut=false param=0x0
17:05:42.315: PutViewPerspective perspective=true
17:05:42.322: PutViewPerspective perspective=true
17:05:42.333: PutViewPerspective perspective=true
You should also find a "navlib.log" file with additional traces.JoelWilliamson wrote: ↑Thu Aug 03, 2023 2:09 pm MyApp.navlib.log now contains these lines after each start up. Is that all the information I should expect?
