My Space Traveeler is just refusing to work with XSI on Vista 64 bit. I thought it was only because I was running the Mod tool but now I am running the XSI 7.0 trial and it still does nothing.
Please ! Any help would be greatly appreciated.
I have got the latest drivers and have set the 3D Connexion driver to have administrator priveleges but nothing helps.
Does not work with XSI on Vista 64
XSI and Vista64
Dear Seamus,
Are you receiving error messages?
Where you using XSI 6?
What are your system spec's?
What do you observe when using the Jet Demo?
What version of 3DxSoftware are you using?
You may want to update your video drivers.
Sincerely
Bryan
Sincerely
Bryan
Hi Brian,
I get no error messages,
I was using XSI 6 mod tool previously and am now using the XSI 7 trial
The system i am using is a quad core 2.4Ghz with 4 Gigs of memory and a GeForce 8800 GTX card
I am not sure what you mean by the jet demo but I can use the virtual Earth and other demos fine
I am using the current drivers Release version 3.6.7
(Driver Version 6.6.1)
Firmware version 3.11
My video drivers are up to date
3DS Max 9 works with the Space Traveller no problem. So far it is only XSI that is causing the problem
XSI 7 and Vista 64
Dear Seamus,
I don't find XSI 7 listed as an application that yet makes use our devices, as listed under the Solutions Menus on our web site.
Sincerely,
Bryan
Sincerely,
Bryan
when installing addon in XSI 7 64bit: ' ERROR : 2000 - Unable to connect the event. File: C:\Softimage\XSI_7.0_x64\Addons\Application\bin\nt-x86-64\\3DxSI.dll
and after that device dosen`t works
in XSI 7 32bit all works fine
in XSI 6.5 32bit also no problems
system: Windows Vista 64bit
Core Quad
Nvidia GeForce 9600
Using 3DxSoftware_v3-6-7
Core Quad
Nvidia GeForce 9600
