can anyone confirm the following behaviour or can provide a solution?
Problem:
When my Mac goes to sleep and wakes up again, the CadMouse Pro movement speed is very very slow.
Fix:
Disconnect the mouse from the USB port and reconnect it.
Configuration:
macOS Monterey 12.6 on a Mac Studio (2022) with an Apple M1 Max chip
3DxMacCore version 1.2.4.307 (307)
3DxWare version 10.7.4 (3493)
CadMouse Pro firmware 1.08
Thank you!
Timo
CadMouse Pro speed very low after return from sleep
infinitytrapdoor
Re: CadMouse Pro speed very low after return from sleep
Are you using an external hub? If so, try a direct connection if your Mac has a USB-A port.infinitytrapdoor wrote: ↑Mon Oct 03, 2022 3:58 am Disconnect the mouse from the USB port and reconnect it.
I can confirm this since one of the latest Public Betas of Ventura.
AFAIK it did not happen again with the latest PB.
The solution was to click for one time first, then the mouse speed
was as expected again here.
I can't remember to have seen that before.
infinitytrapdoor
The mouse is connected directly to the Mac.ngomes wrote: ↑Mon Oct 03, 2022 6:40 amAre you using an external hub? If so, try a direct connection if your Mac has a USB-A port.infinitytrapdoor wrote: ↑Mon Oct 03, 2022 3:58 am Disconnect the mouse from the USB port and reconnect it.
infinitytrapdoor
That didn't work, I'm afraid.
But thank you!
Im having the same issue. I go to the 3dconnexion settings and adjust the mouse speed to bring it back.
Mac Pro M2
Ventura 13.5.1
Mac Pro M2
Ventura 13.5.1
This happens with Bluetooth Cadmouse too. Switching it off and back is the workaround
