3dxpiemenus Uhandled Exception
JimB
Post by JimB »
Hi all,
I have a SpaceNavigator and after installing the drivers (3DxWare64_v10-2-0_r1865)
I have "3dxpiemenus Uhandled Exception" window pop up filling my desktop so much
that I can't screen grab all of it, It appears every time I start my computer I am hoping
that some one can suggest a solution.
Re: 3dxpiemenus Uhandled Exception
Hello JimB,
there might be a configuration that got corrupted. Try removing the existing configurations as described here.
obviousalias
Post by obviousalias »
UtaSH wrote: ↑Mon Nov 24, 2014 11:56 am Hello JimB,
The link takes you to the following info. I don't see how that actually helps resolve the issue. Can you provide more info? I am having the 3dxpeimenus unhandled exception issue now in 2023.
3dconnexion 4-22-2023.jpg (80.75 KiB) Viewed 10394 times
obviousalias wrote: ↑Sat Apr 22, 2023 6:58 am The link takes you to the following info. I don't see how that actually helps resolve the issue.
Looks like a permissions issue. Stop the 3DxWare driver and try to delete the following log file:
C:\Users\nolan\AppData\Local\3Dconnexion\3DxWare\3DxPieMenus.log[/url]
prefabbim
Post by prefabbim »
I went and took that file and moved it to my desktop in case I want to put it back.
Rebooted and the error message doesn't pop up anymore.
I don't know what that file is for. Is it ok to delete it?
prefabbim wrote: ↑Tue Apr 02, 2024 4:39 pm Is it ok to delete it?
The "3DxPieMenus.log" is only used for logging. It is safe to discard it.
