3Dconnexion Spacemouse wireless with Sketchup Pro 2024
Anette
Post by Anette »
Is 3DConnexion Spacemouse wireless possible to use on Mac Os 13.3 with Sketchup Pro 2024?
Or is Some other of the wireless Spacemouse connecting with Sketchup Pro 2024 on Mac 13.3?
Re: 3Dconnexion Spacemouse wireless with Sketchup Pro 2024
SketchUp 2024 is supported, yes.
You will need to use v. 10.8.4 of 3DxWare 10 or newer. The software is available for download here.
NFTM
Post by NFTM »
You must use 3DxWare 10 v. 10.8.4 or later. Software is available for download here.
I would like to use the same as well,
The latest software stops in the middle of installation.
In this situation, I have no choice but to force quit.
I have tried the following, but it just doesn't work...
I would appreciate it if you could tell me how to improve it.
The tester and developer could not reproduce the problem.
However, we were able to find a sort of emergency solution here.
Start/restart the Mac in recovery mode.
https://support.apple.com/guide/mac-hel ... 829c17/mac
Alternatively, you can go to
https://support.apple.com/guide/mac-hel ... 8cf9a8/mac
Disable SIP.
https://developer.apple.com/documentati ... protection
NOTES! Please read the notes in the red box. Re-enable SIP in step 6.
Note contents:
Temporarily disable SIP only to perform the required task and re-enable it as soon as possible. Failure to re-enable SIP at the end of the test will leave your computer vulnerable to malicious code.
Restart the machine
Start the terminal (/Applications/Utilities/Terminal)
Run the following command
systemextensionsctl list
(This will display a list of installed/running extensions. The status of the extension will probably be "activated enabled")
systemextensionsctl reset
(Note: This will also remove any other existing extensions. Probably recommended only if this is the only extension you have)
NFTM wrote: ↑Thu May 16, 2024 6:40 am The latest software stops in the middle of installation.
One scenario where this can happen is if the 3Dconnexion software is deleted (sent to the trash bin) instead of running the uninstaller program.
