Can TDx.SpaceMouse.Navigation3D.dll be used in .net8.0 applications
[email protected]
Post by [email protected] »
The target framework of my application is .net 8.0, can I call "TDx.SpaceMouse.Navigation3D.dll" in my application?
Chengfang
Re: Can TDx.SpaceMouse.Navigation3D.dll be used in .net8.0 applications
It should work, yes, but you need to ensure you have the correct assembly version: .NET Core is available in assembly version 2.0.0.0 (version 1.0.0.0 supports .NET Framework only).
[email protected]
The version of "TDx.SpaceMouse.Navigation3D.dll" which was obtained from 3DxWare_SDK_v4-0-3_r19962 is "1.0.23031.1951", where can I download the 2.0.0.0 assembly ?
The version 2.0.0.0 is installed to the GAC by the driver in 3DxWare 10. You can install 3DxWare 10 and reference the assembly from the GAC.
[email protected]
Thanks ngomes. Is there an official document explaining this part ?
[email protected] wrote: ↑Mon May 27, 2024 8:03 pm Thanks ngomes. Is there an official document explaining this part ?
I believe not but version 2.0.0.0 should be compatible with either .NET Framework or .NET Core programs. You should only need to link to the latter version.
[email protected]
Got it, thanks.
