3DConnecxion Space Mouse not working in Solidworks 2024
imwheels1
Post by imwheels1 »
I have just finished installing SW 2024 and the mouse isn't recognized.
There is no place in the SolidWorks Settings\Systems Options for "3DExperienceIntegration", which other threads have said "holds the solution."
When running the 3DConnecxion Space Mouse Demo, the mouse works as designed.
I am running Win 10 and have the latest driver 10.9.0.
I'm at a loss. All he logical things have been done but no joy.
Any help would be appreciated,
Thank you
skmiec
Re: 3DConnecxion Space Mouse not working in Solidworks 2024
Post by skmiec »
Hi imwheels1
Can you please check in SW 2024 Tools->Add-ins if you have 3Dconnexion plugin and it is enabled?
If it is not there please r-install 3DxWare 10.9.0 one more time when SW2024 is already installed on your PC.
imwheels1
Post by imwheels1 »
Thank you but I reinstalled the driver and in the Plug-ins there is no 3DConnexion there.
The only thing similar is the 3DMarketplaceExperiance and 3DCloudByMe.
Not sure if this is a SolidWorks issue or 3DConnecxion Space Mouse problem.
As stated before, the mouse works in the 3DConnecxion Space Mouse Demo so I'm pretty confident it's something else.
I'm really confused now...
skmiec
Post by skmiec »
Ok, please check if in your C:\Program Files\3Dconnexion\3DxWare directory, you can see a "3DxSolidWorks" folder.
AmroSalih
Post by AmroSalih »
imwheels1 wrote: ↑Mon Aug 26, 2024 7:34 pm Hello,
imwheels1
Post by imwheels1 »
Yes, I do have that folder.
Contained within is a folder \3DxWare\3DxSolidWorks.
The only file of value within is a TDxSW64.dll. The remaining are help files, a .txt and a pdf.
