macOS Sonoma
alexliz
Re: macOS Sonoma
Post by alexliz »
I've got SpaceMouse WIreless (via the USB dongle) and CadMouse Compact Wireless (via Bluetooth) working with Archicad on my MacBook Pro on Sonoma 14.5 - all good.
While viewing PDF files, however, I would like to configure SpaceMouse to allow me to zoom in/out. I tried different ways, including Type Keystroke (and mapped it to hitting COMMAND and the + or - keys but nothing happened.
Any tips would be very appreciated, thanks.
Alex
llealloo
Re: macOS Sonoma
Post by llealloo »
I'm experiencing this too w/ same hardware & OS.
The axes don't seem to be programmable in the "Any Application" configuration in the preference pane. Any way to get this working?
llealloo
Re: macOS Sonoma
Post by llealloo »
Oops ^ actually I have the new spacemouse wireless BT edition (connected via usb) and cadmouse compact wireless (also via usb)
AmroSalih
Re: macOS Sonoma
Post by AmroSalih »
alexliz wrote: ↑Fri Sep 06, 2024 9:48 am I've got SpaceMouse WIreless (via the USB dongle) and CadMouse Compact Wireless (via Bluetooth) working with Archicad on my MacBook Pro on Sonoma 14.5 - all good.
Alex
In which exact application are you trying to view PDF files and configure your SpaceMouse to zoom in/out?
llealloo wrote: ↑Mon Sep 09, 2024 11:35 am I'm experiencing this too w/ same hardware & OS.
https://forum.3dconnexion.com/viewtopic ... 56#p122456
alexliz
Re: macOS Sonoma
Post by alexliz »
My apologies, AmroSalih, I just realized I didn't mention - I'm trying to use my SpaceMouse while viewing PDFs in Apple Preview.
llealloo
Re: macOS Sonoma
Post by llealloo »
Ooh, this would be a great feature! :idea:
AmroSalih
Re: macOS Sonoma
Post by AmroSalih »
alexliz wrote: ↑Thu Sep 26, 2024 1:38 pm My apologies, AmroSalih, I just realized I didn't mention - I'm trying to use my SpaceMouse while viewing PDFs in Apple Preview.
Please visit https://3dconnexion.com/uk/support/faq/ ... plication/.
There already is an existing thread https://forum.3dconnexion.com/viewtopic ... &start=225.
alexliz
Re: macOS Sonoma
Post by alexliz »
Thanks - if you meant for me to post there, I did just now, to recommend Preview support. Other than that, I couldn't see anything helpful at the moment.
sea_dragons
Re: macOS Sonoma
Post by sea_dragons »
I'm able to use my device successfully in Rhino 8 under Sonoma.
Re: macOS Sonoma
3Dconnexion released today (Nov 8, 2024) v. 10.8.6 of 3DxWare 10 specifically to address the "installation stuck" observed by some customers (internally tracked with reference MAC-518). The software can be downloaded from here but if you are already on v. 10.8.5, there is no need to update.
The installer will now check for a corrupted installation of the system extension that can happen if the "3Dconnexion" folder is deleted without first running the uninstaller program. If a corrupted installation is found, a warning panel is shown and customers can follow link to an FAQ article with additional details and how to recover the system (there are different procedures depending on the system version and if the "3Dconnexion" folder can be put back in "Applications"). The FAQ article is here.
On behalf of the Engineering team at 3Dxconnexion, we very much regret how long it took us to understand the root of the problem and we apologise for all the inconvenience it has caused.
zoomer
Re: macOS Sonoma
Post by zoomer »
Fine.
Just that the Downloader still offers 10.8.5 for me
zoomer
Re: macOS Sonoma
Post by zoomer »
Ooops, and now its here, 10.8.6 .....
opus
Re: macOS Sonoma
Post by opus »
Finally, with this installer version I was able to install 10.8.6 :)
It's still stuck on the 3d home connection window. Just throw it in the trash and the problem is solved.
But the shortcuts still don't work... And they worked with the good old spacepilotpro, we could program all the shortcuts key, with all the applications you wanted for years...
But not with the space mouse entreprise or the cad mouse.
When will you make a driver as good as the old one?
Capture d’écran 2024-11-14 à 12.36.46.png (76.26 KiB) Viewed 29909 times
Capture d’écran 2024-11-14 à 12.34.05.png (128.92 KiB) Viewed 29909 times
Re: macOS Sonoma
The system extension must be allowed by the customer before the 3Dconnexion software can function properly.
Only the user can "allow" the system extension even if the software is signed by 3Dconnexion's credentials and has gone through the notarization process. The restriction is imposed by the system.
opus
Re: macOS Sonoma
Post by opus »
Thank you, I know that.
But, no matter how many times I tell it that it's allowed to run, that window comes back every time I start it up.
I've just tried to uninstall it (with your uninstaller) and now I get this alert. See attached screenshot.
an idea?
Capture d’écran 2024-11-14 à 15.55.32.png (249.76 KiB) Viewed 29897 times
