dpi mouse
harmen1908
dpi mouse
Post by harmen1908 »
what is the min, max and default dpi of the mouse?
i come from a gaming mouse and would like the same dpi settings.
there arent any numbers with the slider.
luping
Re: dpi mouse
Post by luping »
Default DPI is 7,200 , no option to change, the CadMouse series is not made for gaming.
nutevas
Re: dpi mouse
Post by nutevas »
Consult the Manufacturer's Website: Look up the model of your mouse on the manufacturer’s website. They often provide detailed specifications, including DPI settings.
User Manual: If you have the manual for your mouse, it should list the DPI settings.
fieldscontainer
Re: dpi mouse
Post by fieldscontainer »
According to my research, Minimum DPI is about 100 DPI, or maybe 50 DPI. maximum DPI can vary widely depending on the mouse 16,000 or 3,000 DPI. Default DPI with a default DPI setting of 800 DPI or 1000 DPI, which is often suitable for everyday tasks. Gaming mice may default to higher DPI settings, like 1600 DPI or 3200 DPI.
2010MousePlsUpdate
Re: dpi mouse
Post by 2010MousePlsUpdate »
harmen1908 wrote: Sun Sep 15, 2024 4:58 am what is the min, max and default dpi of the mouse?
There is no dpi setting in the driver or switcher on the mouse. Just have to adjust windows pointer speed to get it close enough
Coming from a decent mouse(gaming) the first thing you'll probably notice if you are looking at cadmouse wireless is the polling rate. 125hz wireless iirc is pretty abysmal in 2024. Good mouse otherwise, but it feels like I'm pointing with a slug sometimes.
sailorsscale
Re: dpi mouse
Post by sailorsscale »
Minimum DPI: Typically ranges from 200 to 400 DPI. This allows for fine control in tasks like graphic design or photo editing.
Maximum DPI: Many gaming mice offer a maximum DPI from 1600 to 16000 DPI or even higher. Some high-end models can go up to 25,000 DPI.
I think so.
